Question about Nintendo DS Lite Console
Sound coming from headphones is different from sound coming from speakers
This just started happening. All my games play normally through the speakers. However, half the background instruments and sound effects are missing when playing through my headphones. They're in all the way, the sound is up, and i've used different pairs. I can hear stereo sounds. It's just that some sound effects etc don't play through the headphones. What is up with that? Do I need to have it repaired? As I said before, it happens with many of my games. So far, in fact. every one i've tried has the symptom. INCLUDING the system menu.
    Problem Solver:
  • 13 Answers
Make sure you set the sound in-game to head phones. Look in the game's options.
Posted on Aug 18, 2007
No sound on computer
hi nina.this could be a lot of reasons why you have no sound.
Update the audio driver using Device Manager as follows:
  1. Connect to the Internet.
  2. Click Start , and type device manager into the Start Search field. ...
  3. Double-click Sound, video and game controllers. ...
  4. Right-click the name of the audio device listed under Sound, video and game controllers.
  5. Select Update Driver Software...
  6. If your computer is having problems playing sound, try using the Playing Audio troubleshooter to fix the problem. It checks for common problems with your volume settings, your sound card or driver, and your speakers or headphones. ... Under Hardware and Sound, click Troubleshoot audio playback.
  7. If you hear sound through the headphones, the sound hardware on the computer is working, and the issue is probably related to the speakers or speaker cables. Disconnect the headphones and reconnect the speakers. When done, test again forsound using the same steps as above with the volume control slider.
  8. If you are running Microsoft Windows, make sure the speaker setup is correct by following the steps below. Select Hardware and sound or just Sound in the Control Panel window. In Windows XP and older, click Manage audio devices under Sound. On the Playback tab, select your speakers and click the Configure button..
  9. or go to this link if you need mote help.
No sound on computer Google Search
Nov 05, 2017 | Computers & Internet
Cant get to play music without headphoes
Most modern computers come with internal speakers already installed, especially laptop computers.
These speakers may be sufficient if you are performing typical computer tasks, but when you play computer games, listen to music or watch movies on your computer, you may want louder and more vibrant sound.
You can achieve this by installing external speakers or headphones. These can be connected to your computer through the speaker or USB ports included on your computer.
Plug in the speakers or headphones.
If the speakers or headphones use a stereo plug, insert the plug into the speaker/headphone port normally located on the side or front of your computer.
This port is often color-coded green. If the equipment is connected using USB, locate a free USB port.
Some external speakers will also need to be plugged into a power outlet in the wall or your surge protector.
This may be all you need to do to get the speakers or headphones to work. If they do not, continue to the next step.
Open the audio settings on your computer.
From the Windows Start menu, open the Control Panel. Here you will find audio and sound settings.
Click the heading to see your sound and audio options.
Choose "Manage audio devices" in Windows 7.
Find your Playback device.
In the Playback tab, you can select your speakers and set them as the default for your system.
If you do not see your speakers or headphones, they have not been installed properly. Disconnect and reconnect them to see if it corrects the problem.
Configure your settings.
Select your device from the list and click "Configure" to test your settings.
You can adjust the volume by using the volume slider on your computer's task bar or using external controls on the speakers or headphones.
Install speakers
http://www.liutilities.com/how-to/install-speakers-to-a-computer/
Aug 05, 2013 | Acer Computers & Internet
Whenever I start the computer, I dont hear any sound from window and if I try to play music from my media player, no sound at all. I can only listen to music or sound via headphone only. I have downloaded...
most system has seperate audio ports for the speaker and the headphone but they are interchangeable. try plugging the speaker on the audio your using for the headphone. if your already using the same audio jack then try using another speaker, but since you mentioned that the headphone works then its possible you might need to replace your speaker
Mar 29, 2011 | HP Computers & Internet
My sony vaio has no sound coming from the speakers i have tried to uninstall and install the drivers but nothing is working the sound appears to be on as media player has no problem playing anything. my...
attempt to connect external speakers or headphones. if thet work, your internal speakers are the problem and needs replacing. you may also at least check the sound properties and under playback section, make sure the correct playback device is selected. Normally, it should be the speaker/headphone audio device unless you use digital playvack device.
Dec 31, 2010 | Audio Players & Recorders
Can 2.1 pc speakers work thru headphone jacks?
No it's not possible to have a sound. Because the HDMI and the Headphone (3.5mm jack) are on two different technologies.
The monitor does not have a way to convert the sound from HDMI to Headphone.
There could be a converter that might convert the sound signal from HDMI to headphone (but I'm not sure).
Aug 30, 2009 | Logitech X-540 Computer Speakers
No sound coming out of the left speaker
It sounds like you have a break in your cord right where it joins the plug. You will either have to replace the plug or buy new headphones.
May 18, 2009 | Audio Players & Recorders
Acer Aspire 1406 no sound issue
So sometimes laptops play up when the headphone socket gets a bit worn. If you wiggle a headphone jack in the socket (put it in at different angles, and rub around) sometimes the sound will come back.
There are two prongs that "detect" the headphones, and cut the speakers... and if they don't "un-contact" when the headphones are removed, the speakers stay off.
You'd need someone to solder a new headphone socket on the mainboard to properly fix it, but if you wiggle and get the speakers back, they should stay back until you use the headphone socket again.
Apr 20, 2009 | Acer Aspire 1406LC Notebook
Nintendo DS Lite Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
juanmireles1
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
