Question about Fisher and Paykel GWL11 Top Load Washer
Machine not filling with hot water
GW712 - Recently moved house and since moved machine will only occasionally fill with hot water.. Bowl will spin but no hot water will come in, machine does not beep.. Have checked at water source and runs freely when not attached to machine.. Also the pressure of the water entering the machine is not as strong as previously.
  • 30 Answers
First check the filters in the inlet hose and hot water pressure. Sounds to me like the hot water valve is faulty. Test the w/machine on a hot water cycle, if you hear a noise and its not filling it up with water,its a faulty hot water valve. Air pressure?? change the water valve and remember it has a little rubber boot on the old water valve, transfer this to the new valve,or go into option adjustment mode and change you wash temperature settings.
Posted on Aug 15, 2007
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
My Fisher and Paykel mw511 intermittently will not fill with cold water. The bowl spins slowly as if it should be filling with water and I can hear a pump but no water comes out. I swapped the hoses and...
Cold water valve problems with F&P machines are common. Replacing the cold valve is the most likely remedy.
It's not good policy to use the hot valve on the cold inlet because (we are told) they are different in their tolerance of high water pressure. (don't shoot the messenger!!)
As you've changed the valves, you've already seen that the problem can be removed...
Good luck.....Nomess
Aug 06, 2010 | Washing Machines
Black type residue being left on clothes
This is a common problem on washing machines, if you predominantly do cold washes.
Over a period of time, a washing machine will accumulate a buildup of Soap Scum (excess soap & softener residue) which can stick to the inside of the drum.
This black coloured soap scum occasionally breaks away from the drum, and attaches to the clothing fabric during the wash cycle.
You can rectify this, by doing the following:
Firstly, purchase a packet of CITRIC ACID from your local grocery store (usually found in the baking isle).
Do the following procedure before going to bed:
1) Do a HOT WASH without clothes (Hi water level, with HOT water) - allow machine to fill with hot water, then add the CITRIC ACID to the water. Allow the machine to complete a FULL wash cycle (i.e. allow machine to agitate for 30 mins or so, then drain).
2) Fill the machine again with the HOT water / CITRIC ACID solution, but this time allow it to sit in the bowl overnight (no cycle).
3) Next morning, set machine to spin & drain (i.e. to empty the solution)
4) Set machine to fill with FRESH HOT WATER ONLY (no citric acid), then set machine to spin & drain. This will flush all remaining residue left in the bowl.
Note: Soap scum residue is caused by using excess detergent/fabric softener. Hot Water flushing should be done every 6 months.
Contrary to what the detergent manufacturers state, you should follow Samsung's instructions by using HALF the recommended detergent.
Samsung machines prefer LOW SUDS, and you may find by reducing the amount of detergent used, you may even eliminate the buildup of soap scum.
"If this has helped resolve your issue, please rate this solution"
Oct 31, 2009 | Samsung SW62ASP Top Load Washer
I have a Samsung SW62ASP top load washing machine. I keep getting chunks of black flaky stuff turning up through my wash. I always empty the in bowl filter, is there another filter?
Aug 05, 2009 | Samsung SW62ASP Top Load Washer
Washing Machine Rinse and Spin lights are on
its the problem of drum getting blocked by any clothes getting tucked up.also try to move the drum manually with the machine off.if it makes any noise its the faulty motor.or drum has lost its alignment.it needs to be reseated properly in that case. -------------- The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Jul 23, 2009 | Tricity Bendix AW1400W Front Load Washer
Water flow into machine dribbling - Fisher and Paykel GW712 (AU)
The first thing that needs to be done is to disconnect the fill hoses from the back of the machine. Once disconnected, look at the inlet valve screens and check for blockage, if clear, open the water valves and check for water flow through hoses, if not clear, clean screens at fill valve, reconnect hoses & check for operation. If the problem remains, then the problem is with the machines fill valve & it would need to be replaced
Apr 30, 2009 | Washing Machines
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
F & P GW712 - bowl spins, but won't fill.
Read your user manual - but I would suggest that you may not have setup the balance properly. Check the level of the machine and adjust to be as square as possible by adjusting the feet at the bottom. If the water isnt coming in on both hot and cold sounds like a common problem - perhaps the water level sensor is playing up or something else has been knocked during transportation of the machine when you moved house. Check your user manual for troubleshooting. Sounds dumb, but check that 'delay start' isnt selected also. check both hoses filters are not blocked.
Sep 21, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing machine wont fill with hot water
if you pull the filter out of you (hot water) valve with a pair of long nose pliers you will see a black rubber seal. pull this rubber ring put as it acts like a restrictor.
Aug 15, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
443 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
jimorris77
Marvin
Marvin
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
