Mitutoyo is a brand that produces precision measuring instruments such as micrometers, calipers, and height gauges. An error code E940 on a Mitutoyo instrument typically indicates a problem with the instrument's communication interface. This can be caused by a variety of issues, such as a problem with the instrument's cable or software, or a problem with the computer or device to which the instrument is connected.
To troubleshoot the issue, you should first check the connections between the instrument and the computer or device to ensure that they are properly connected and secure. If the connections appear to be fine, you may need to update the software on the instrument and computer or device to resolve the issue.
Mitutoyohttps://www.mitutoyo.com > Contact Us
Whether you need immediate repair service or A2LA Accredited, NIST-traceable calibration of your measuring instruments, our highly skilled technicians provide ...
Hello. Here is the link to the height gage page(s) at Mitutoyo, Find the unit you have to verify model/serial number and then access their "contact us" option - they will be able to assist you. Hope this helps, if it does please rate it a four-thumbs up. Thank You.
This is not uncommon for a gage like this with such a close tolerance. A small change in temperature can cause this gage to jump off zero due to the thermo-expansion of the materials in the gage itself. If you were to set this gage on a part, zero it out, and just breath on it, the temperature change created by the heat in your breath will cause it to change. The gage is not faulty (unless it is reading way out of range), it instead is probably giving you a very exact reading.
