Question about Canon ZR50MC Mini DV Digital Camcorder
ZR50 Rec/Pause button not working
The record/pause button on my ZR50 does not work. I cannot get the camera off of pause to record video. The camera works fine with the remote control, so I believe the problem to be the actual switch. How do I disassemble to fix or replace the switch?
  • Andre Trollope Sep 10, 2007
    Thanks for your acknowledgement. However, I need assistance in how to disassemble the camcorder to remove and replace the switch. I have had know success on finding repair manuals on the web.
    Regards,
    New Friend:
I encountered the same problem with the Canon REC/Pause switch was intermittent. To solve the problem I used a high pressure air hose and blasted the switch with air. It cleaned the contacts of the switch without having to take it apart.
Posted on Aug 06, 2012
  • Andre Trollope Aug 09, 2012
    thanks for the input. I will give it a try.
  • 169 Answers
You are right.. if you know that you can fix the carbon button..replace it with the metal contact of the tac switch or micro switch...the diameter of the contact must be bigger to the contact area to prevent shorted connection
Posted on Aug 15, 2007
SOURCE:
I want to record but i can't cause of the pause button
then don't push pause try record instead .
Nov 21, 2015 | JVC GR Video Cameras
All the buttons on the device do not work in the "recording mode"
only possible solution would be to format the recorder to see if anything changes... make sure to download files before formatting the recorder. format is found in the menu
Jan 20, 2009 | Olympus DM-20 Digital Voice Recorder
Telephone recording won't work
You need to have a telephone record adapter plugged into the back of the 3750. Then you press and hold the Tel Rec button until it begins recording.
Also check to see if the 'Vox' or 'VA' switch is on (voice activation). This will cause the machine to pause if the volume is too low.
Jan 15, 2009 | Dictaphone 3750 Desktop Cassette...
Recording
press rec button again,sometimes certain cameras have built in or auto mechanism that keeps the user from leaving camera record on.
May 30, 2008 | Panasonic Palmcorder PV-GS12 Mini DV...
MyMusix MP3 Player
All documentation for this product is available at www.mymusix.com
Voice record
Use the built-in microphone to record voice in the voice mode.
1) Press "Rec" button to begin recording
2) Press "Rec" button again to stop recording
3) Press " play/pause" to pause or resume recording
4) Recorded files are stored as default files VXXX.WAV, XXX numbered from 001
-Tha Mp3 Doctor
Apr 03, 2008 | MyMusix PD-6030 MP3 Player
Canon ZR 50 - pause / record button does not work
DId you check the second Battery. The small circle one under the main battery? That was the case with mine. The pause, rec button wouldnt work until i replaced the small circle battery.
Jan 27, 2008 | Canon ZR50MC Mini DV Digital Camcorder
Recording
I think it should be possible. As long as you don't exceed the resolution of the DVD player. It should work fine. Just keep DVD player in Rec / Pause mode then hit Rec button when you want to record a clip, then pause it again. That should work fine. Have a good night. Jay
Jan 19, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
How do I pause while recording?
As far as I can tell, and yes the documentation is skimpy, when you press the 'record/play' button the video recording pauses. Make sure you press the video icon button, not the 'record/play' button to get it started again. If you press the 'record/play' button, it goes into a 'play back' mode.
Hope this helps...
Dec 26, 2007 | Jazz DV-179 Digital Camera
Canon ZR50MC Mini DV Digital Camcorder Logo
132 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
