Question about Sangean ATS 606 AM/FM/SW Radio
Sangean ATS 606 A Portable Radio
My little Sangean has stopped working when asked to draw power from its batteries (when not hooked up to AC and you press "on", it goes to the station for an instant and then flashes E) but it continues to draw power from the batteries and they have maintained the preset station information over a couple of weeks. I've tried several different sets of batteries to no avail. The radio works fine when hooked up to electricity, but that kind of negates its appeal as a portable. Any suggestions? And...if it has to go back to Sangean to be repaired, is it worth it, it's about 6 years old? Thanks, Ed Waldock
  • 1 more comment
  • badrul Dec 21, 2007
    I got myself a SIEMENS RK 659, which is SANGEAN ATS 606 equivalent. I have a problem which is almost similar. I have been using it with an adapter. But when i change to using batteries, after a couple of days (in off position) suddenly the radio just stop working. I tried using the adaptor but to no avail. Help please!
  • albback Mar 21, 2008
    Yes, mine "eats" batteries, now. It is about 6 years old. With the radio on or off, I still have to change out the batteries every three days. It's maybe only on for 4-6 hours total during that time. Sometimes, only an hour or two. I put the lock on whenever I turn it off, so there's no chance of it accidently turning on. And, I use top quality Rayovac industrial batteries in this radio as well as other appliances. The battery type/brand is definitely not the problem.
  • Anonymous Mar 16, 2014
    I bought this new from the US. Couldn't get it started because of 240/125v difference (fuse blown?). Can you have a look for repair? Thanks
Remove the battery compartment door and the batteries. There should be a small hole marked "reset" under the upper battery cradle. Press (gently...until it clicks) and hold for 5 seconds. Replace batteries and try again.
Posted on Aug 06, 2008
Has this been resolved yet? Mine worked fine yesterday and today I get nothing but three zero's (000) in the screen...no buttons work (and the lock switch is off). Has anyone run into the issue of no power (note: I have only used battery power so far with the radio).
Posted on Mar 04, 2008
I have a Sangean ATS 818cs portable radio but no 6v lead input
Yes you can use any 6 volt DC for your radio but the most IMPORTANT thing to remember is to connect the terminals in the correct direcction. First of all you can solder a red wire from the positve terminal of the battery and a black wire from the negative terminal of the battery. This must be connected to the source of your 6 volt battery.You can buy a good DC jack socket female to be fitted into the vacant spot of your radio and use a male jack to supply the DC. Only be carefully to see the polarity. To avoid any reversing of polarity use can even connect a diode in the forwarrd bias towards the positve terminal. This will prevent any wrong connection of polarity to damage your set. Helpful? Good day
Jul 13, 2010 | Sangean ATS 818 AM/FM/SW Radio
Sangean ATS-803A - no audio
If its not a micro-p glitch, sounds like the radio was subject to a spike or surge wile plugged into the AC adapter. If the "power" light stays on all the time, thats what happened. Believe me, I was Sangean America's tech from 1990-1995.
Rob
The fix is to replace a transistor, or fet in the main pwr supply. (Close to where the adaptor plugs in.)
I wish I could give more details, but its been 14 long, long years.
Jun 03, 2009 | Sangean ATS 808A AM/FM/SW Radio
Didn't lock radio before changing out batteries--now, no power! what can I do?
Unplug AC adapter from radio. Remove ALL batteries. Wait 15 min. Reinstall batteries
Apr 22, 2009 | Sangean ATS 818 AM/FM/SW Radio
Wiring schematic for Sangean ATS 818cs
Yes, go to:
www.thiecom.de/ftp/sangean/ats818/ats818acs-servicemanual.pdf
Jan 01, 2009 | Sangean ATS 818 AM/FM/SW Radio
Sangean ATS 803A
Don't be mis-led by the working display. I had the "no power" problem with a working display too. I measured the voltage of the two AA batteries. One was 1.33 volts and the other was only 0.76 volts. Replaced the weak AA and everything worked. I suspect the 'enable' circuitry fails around/below 2.1v.
Sep 27, 2008 | Sangean ATS 808A AM/FM/SW Radio
WX cc Sangean radio cuts out
The ATS-818 needs a transformer. The transformer converts AC power to the DC used by the radio, so no. You need the transformer.
Jan 20, 2008 | Sangean ATS 818 AM/FM/SW Radio
ATS 818 Inoperative
Jan 17, 2008 | Sangean ATS 818 AM/FM/SW Radio
SANGEAN ATS505
try the power switch a few times and more force than usual.
Sep 16, 2006 | Sangean ATS 505 AM/FM/SW Radio
Sangean ATS 606 AM/FM/SW Radio Logo
833 people viewed this question
Top Sangean Audio Players & Recorders Experts
Oloyede Monsuru
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
