Question about Kicker R3 Car Mid-Range
My amplifer will cut on and off between on and protect.
The amplifier i have is a kicker impulse 1252 it is 2 channel and bridgable. The problem is that every time it goes to push the watts to the subs it fails and goes the protect mode and shuts on and off. I really need to fix this so please someone help.
    New Friend:
Protect mode is a good thing but frustrating as well.... KISS keep it simple stupid... 1. good solid ground 2 amp, closer better 2. good steady 12volt current reading, some amps will go into protect mode when starved of juice... 3.one wire at a time left sub neg. right sub neg. 4.again one wire at a time left pos.right pos.... ALL WIRING TO BE ONE PEICE UNBROKEN AND CORRECT AWG...... dont bridge anything out or go crazy until this very basic and to the point way is working for you.. ull drive yourself crazy make sure of no reverse polarity.. very common mistake....
Posted on Nov 03, 2013
  • 113 Answers
Try with one sub at a time to see if bad sub
Posted on Aug 22, 2007
I have a kicker impulse 325 xi 2 channel amp and it keeps cutting out and the power light will be glowing red and fade out and pop right back on over and over consistently how can I make it so my amp stops...
It is likely that your amplifier is going into thermal shutdown repeatedly because the output is shorted or the speaker impedance may be too low or for some other reason such as component breakdown.
Oct 30, 2013 | Car Audio & Video
How do you connect wiring to bridge an adcom gfa 5300?
The manual does not specify a bridging option.
http://www.audioreview.com/cat/amplification/amplifiers/adcom/gfa-5300/prd_116265_1583crx.aspx
"Weaknesses:
Not bridgable."
Generally an amp that IS bridgeable uses the positive speaker terminals and some switching method to tell the unit to run as bridged. This is NOT a recommendation to try it on the 5300.
Aug 02, 2011 | Adcom GFA-5300 2-Channel Amplifier
Is a Adcom GFA-7500 5 channel power amplifier bridgable?
no this AMP is not bridgable to get more power out of this amp you need 4 ohm speakers.
Power rating
1 - 150 watts into 8 ohm speakers
1 - 225 watts into 4 ohm speakers
Feb 23, 2011 | Adcom GFA-7500 5-Channel Amplifier
Have a kicker 350 4 played to loud stuck on protection
contact eric @ Capital Audio & Electronics Repair 850-339-1130 we repair all brands & all models
Mar 12, 2010 | Kicker KX350.4 Reed Multi-Channel Amp -...
How many watts are in the kicker comp zr600 amp? i was told that it was a 1000 watt amp. i just want to make sure that it is a 1000 watt amp and not a 600 watt amp. i am powering two 15'' kicker comp subs...
  • Amplifier Type: Dual Channel
  • Bridgable: Bridgable
  • RMS Power at 4 Ohms: 150 W x 2
  • RMS Power at 2 Ohms: 300 W x 2
heres a link to a stats page for the zr600>
http://www4.shopping.com/xPO-Kicker-ZR600#keyFeaturesArea
Feb 05, 2010 | Kicker ZR600 Car Audio Amplifier
WHATS THE WATTS ON THIS AMP
Feb 04, 2010 | Kicker ZR600 Car Audio Amplifier
Is it not bridgable
This amp isn't bridgeable. It's a mono amp (only one channel). You need two independent channels to bridge. Some mono amps are bridgeable if you have two identical amps but I don't think Kenwood recommends that with this amp.
Jan 27, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kicker amp troubleshooting
Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Dec 01, 2007 | Car Audio & Video
Bridging
Yes and no lol. I sold that product about three or so years ago. That amplifier is whats called a mono amp. The outside shows two channels but they are still tied together. Think of it as a hose with a Y on it so two lines can run out from it. Its still the same amount of water whether you use both hoses or not. So bridge it if you want to but it will for looks and looks only. Note that amp is only two ohm stable so be careful what woofers you use. You will want two single 4 ohm woofers for a regular instalation. DO NOT USE Dual 4 ohm speakers Good Luck
Nov 17, 2007 | Car Audio & Video
Kicker R3 Car Mid-Range Logo
143 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
