Question about Palm Treo 600 Handheld
Palm treo call log
A problem started today. whenever I enter the call log, the phone resets. Before this started, I got 2 phone calls from a restricted # and no one was there. Could this be a virus? I am holding off on hot sync.
Purge call log.
That's it!
Cant get to call log without it shutting down?
Call your self, leave message, then hang up. Then get to call log from there.
Tap upper left corner I think under file and find purge.
found out how to do that in the Treo book and on this website together. My wife got a new Treo phone out of it though thinking it was broken. Even the "techs" had not a clue. They could have looked online.-Found this site in 8 minutes.
Posted on May 12, 2008
I don't know how long you've had the phone or when was the last time you trimmed the log, but I recall having my T600 show very odd behaviors (incl. resets) when my call log grew over a certain size. I could not sync it and I had to purge it out of the backup folder on my PC (hard reset the Treo) and then all was good. Had to take the loss on my call log though. Not sure if that's your issue but worth looking into. btw, if memory serves I think my call log was either 1 or 2 mb in size when it became a problem, but not 100% sure.
Posted on Aug 24, 2007
SOURCE:
Hi how to unlock my palm 650 to used outside of USA
You can use the Unlock code to Unlock Your Palm-One Tero 650 model Phone,You can get the Unlock code from here
Wickedunlock and follow the instructions and Unlock it step by step..
Palm One Treo 650 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Palm One Treo 650 mobile phones. If you enter over a certain amount of wrong unlock codes on your Palm One Treo 650 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Palm One Treo 650 with an ACCEPTED SIM Card,
2 - Go to Menu and select "Phone Tool" or "Phone Application",
3 - Type on Virtual Keyboard *#*#CODE#,
4 - Select with PEN "Numer" and Palm One Treo 650 will show that it's unlocked now!
or
1 - Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
2 - Enter the Unlock Code we send to you.
or
1. Remove Palm One Treo 650 battery, unplug cable,
2. Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
3. 'Sim not allowed' is displayed, click OK,
4. Go to the dial pad, and dial *#*#CODE#,
CODE: The unique unlock code for your Palm One Treo 650.
ACCEPTED : We mean, to use a sim card from the network your Palm One Treo 650 is locked to.
NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Palm One Treo 650 is locked to.
Jul 10, 2011 | Palm Treo 650 Smartphone
Palm Treo 700W Smartphone is stuck on speaker phone
Soft Reset
A Soft Reset stops all active (or open) programs and "reboots" the handheld. When the Treo powers back up, you'll start with all programs closed and the unit will be ready to use. The soft reset is intended to reset the Treo if it is malfunctioning or has become bogged down.
The Palm Treo 750 can be soft reset by quickly pressing and releasing the tiny red button beneath the miniSD memory card door:
diagram.jpg Hard Reset
A Hard Reset wipes the internal memory and returns the Treo to its factory specs, in effect returning the Treo 750 to the state it was in when you purchased it. All data entered, preferences set or software installed on the Treo after purchase will be lost after a hard reset and will have to transferred or reinstalled via ActiveSync / Windows Mobile Device Center.
power_button.jpg The Palm Treo 750 can be hard reset by pressing and holding the power button (seen left) while at the same time pressing and holding reset button beneath the miniSD memory card door. Press and hold the two buttons until the screen completely fades. When the screen returns, you'll be given the option to "Erase all data." Select Yes to complete the hard reset. The Treo will now be as it was when it left the factory and you can start fresh. You may have to perform a soft reset after the hard reset to get the unit to power on.
May 11, 2008 | Palm Treo 700w Smartphone
Palm Treo 750 "no service"
my favourite (treo 750) i own 1 but not sure i have had that problem yet depending on if you install a program it could be causing that problem maybe a call blocker! u could check to see if ur network is on automatic
start-setting-personal-phone-network-netselection automatic
try backing up your phone data then master reset back to factory setting
N.B you would loose everything that cannot be backed up but this solved my bluetooth problem 1 time holding down the reset button then press power. when prompted to reset say yes
Feb 01, 2010 | Palm Treo 750 Smartphone
Wireless mode of my treo 600 constantly off
have you tried to hard reset the unit - backup your personal data before you do
Sep 01, 2009 | Palm Treo 600 Handheld
Frozen Screen on Palm Treo 755p
mayb you can try to do a hard reset.
Take out your battery press and hold end call button ( don't release ) then put in your batery wait the loading finished and change to other screen then you release your from the end call button you pressing just now.If still can't work,no choice need to go back to you service center .
Dec 28, 2008 | Palm Treo 755p Smartphone
The phone feature won't turn on!
i have palm treo 680 mobile phone
i have use any sim my phone
Jun 28, 2008 | Palm Treo 680 Smartphone
Touch screen not responding
There is a treo repair website that shows you how to replace the screen yourself.
May 04, 2008 | Palm Treo 750 Smartphone
No internet access with palm treo 700w
Sad to say - you need to go get out your phone bill and call Sprint - they may need to fix their end of the internet connection. They often disconnect services you have paid for and can't use. In any case their tech support is pretty good. They can also reset your password and let you know your text message address.
Dec 22, 2007 | Palm Treo 650 Handheld
Battery indicator/charging defect
Do you have a Treo desktop charger/sync cradle where you can drop the battery into the charger?
Jun 14, 2007 | Palm Treo 650 Handheld
Palm Treo 600 Handheld Logo
595 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
