Question about Kenmore 62109 Microwave Oven
Kenmore microwave 86050
Is there a quick on to a set number of minutes on high? e.g. How to get it to be on for 6 min on high.
  • Kenmore Master
  • 9,150 Answers
Please post your model number so we can check for the owner's manual.
Posted on Oct 12, 2007
Need 800 number to call for service
1-888-923-8482 whirlpool customer service phone number for service appointment
Dec 02, 2012 | Emerson MW8102SS 1100 Watts Microwave Oven
Kenmore 64664300 microwave. 6 years in service. Heated cup of water very hot in 1.45 min. Next use only warmed the cup of water. Would not pop corn as before. Installed new OE...
Timing a known quantity of water to boiling is probably the best way to make routine comparative checks on the efficiency of a microwave.
You have done more than most folk would do and have done almost all an ordinary handyman can do. Microwaves are now so inexpensive it is hardly worth repairing them now.
Probably the new magnetron is short of drive. There could be a problem with the supply to the transformer, the transformer, the rectifier or the capacitor.
There is a limit to how many multimeter tests can be done with a dead circuit before the voltages must be checked while it is operating.
The transformer has two outputs, one low voltage for the magnetron heater and one high voltage to drive the magnetron. The high voltage output CANNOT be checked with a normal multimeter!
The maximum range of a normal multimeter is likely to be 600 volts or maybe even 1 kv but the transformer output should be at least 2800 volts and could be as high as 3500 volts.
A special voltmeter for measuring high voltages would be prohibitively expensive and even an eht probe to convert an ordinary meter is painfully expensive.
Sep 06, 2017 | Kenmore Microwave Ovens
I have never used the power feature and now I need to and cant find manual. How does the power feature work. I need to operate the microwave on medium power for one minute.
1 Use the number buttons to set a cooking
time. You can set a time from one second to
99 minutes, 99 seconds. To set a time over
one minute, enter the seconds too. For
example, to set 20 minutes, enter 2, 0, 0, 0 .
2 If you want to set the power level to
something other than High, press the Power
Level button, then use the number buttons
to enter a power level.
Power Levels:
Level Cooking PL
1Warm10
2Low20
3 Defrost 30
4Medium Low40
5Medium50
6 Simmer 60
7 Medium High 70
8 Reheat 80
9 Saute 90
10 High Hi
Hope that helps.
Mar 01, 2011 | Emerson MW8107WA Microwave Oven
I have a kenmore microwave , how to make its power high ?
That should be the default condition.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Then I would refer you to the owner's manual.
If for some reason you don't have yours, you should be able to download it from the Sears parts site.
Just enter your full model number there.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
On the resulting page, look to the right for the blue "View manuals" button. Click there.
view_manuals_button.jpgview_manuals_button.jpgview_manuals_button.jpgThat Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will also have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
For repair service on Kenmore appliances, see Sears Service.
Sep 07, 2010 | Kenmore 80412 Microwave Oven
Reduce heat
Normally it's one of these two sequences to cook at 1 minute at 60% power:
Time Cook, 1, 0, 0, Power Level, 6, Start
or
You can download many Kenmore owner's manuals free.
Enter your full model number at the Sears parts site.
Sears parts site.
May 04, 2010 | Kenmore 63792 Microwave Oven
My maytag microwave mmv1153bab cooks for about 4 min on high and then shuts off compleatly lights and all then 10 min later comes back on with a :0 in the display window what do I do
Run it with the exhaust fan on high,if this helps, the unit is over heating and has a bad cooling fan,Magnetron or Magnetron thermostat.
Sep 16, 2009 | Microwave Ovens
Various buttons on Kenmore Microwave Oven Model: 87133 doesn't work
On some models hitting popcorn will make the microwave come on for like 2-1/2 Min's.....then shut off....Maybe yours is like that...It's also on high power
Dec 07, 2017 | Microwave Ovens
Buzzing
I do not believe you need to be concerned about radiation leaks since the cabinet and door are properly designed to prevent that however the buzzing sound could be any number of things that could range from a simple fan to the magnetron tube failing.. That particular model is relatively inexpensive and service calls are not. In my opinion, it just isn't worth the costs associated with having it repaired when you can buy one for comparable money. You might find a local repair shop and have it examined and get an estimate of the cost to fix. If the costs to repair exceed the costs to replace then the obvious choice would be to replace. Your call..
Aug 23, 2008 | Sunbeam SMW777 Microwave Oven
Kenmore 62109 Microwave Oven Logo
167 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
