Question about Canon WC-DC58A Wide Converter for S2IS
Canon S2IS Friends are touring Europe and presently in the Alps, with a broken camera. They asked me to try and find a solution. The problem is with the zoom...when they full zoomed the camera stuck and quit with a message 'E18'.
Had the same problem after 2 years and 12000 shots on the camera.
couldn't fix it myself using above suggestions.
The easiest solution is to buy a new camera.
Posted on Mar 19, 2008
Little knowledge is dangerous. The best way is bring the camera to a qualified technician, Do try to consult the service center for repair but first ask for the charge because if you fail they might charge big enough that can buy new camera better than those you purchase before....... JAgger
Posted on Feb 29, 2008
    President:
  • 1,114 Answers
The Ei18 error is so infamous that it now has it's own wikipedia entry & webpage! See below: http://en.wikipedia.org/wiki/E18_error http://www.e18error.com/ Tips on how to try & fix it are as follows: Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode. 1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on. 2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine. 3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works. 4) Try forcing the camera lens: Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended. Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on. If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on. Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 15, 2007
SOURCE:
Maximum sd card for canon powershot s2is
SD cards max out at 2GB. The S2 will not work with higher-capacity SDHC cards.
Mar 27, 2013 | Canon PowerShot S2 IS Digital Camera
My computer do not recognize my canon vixia hf20 double click on my computer icon : computer do not recognize the camcorder canon vixia hf20
Be sure that you have installed he driver correctly ..and the cable is well plugged...,another thing to check is the camera's display and see if it asks for a connection confirmation in the moment you plug it in ...if it does..choose PC connect ..and after that will work ..
also check into the device manager and see if the camera is present there ..even if it appears in yellow with an ask sign on it ...this meaning that the driver is not installed or damaged or not the proper one..
http://software.canon-europe.com/products/0010719.asp
select the operation system ..download ..reinstall and go for it ...but first check what I suggested..
Dec 24, 2010 | Canon VIXIA HF20 High Definition Camcorder
S2Is black screen
It may be out of warranty. If its stil under warranty you could contact Canon from www.canon.com
Jul 10, 2009 | Canon PowerShot S2 IS Digital Camera
The lens on my Canon S2IS will not open. It tries
hi..the gears might have got jammed.Take it to the
service,it needs a expert.
check it out..
thank u..
kindly rate my response..
May 08, 2009 | Canon Cameras
How to transfer photos from Canon S2IS to laptop
Please see the following blog article, as it describes the use of a card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
Apr 17, 2009 | Canon PowerShot S2 IS Digital Camera
How good is this bike for long tours?
The bandit 600 would be great for the twists and turns on european roads, but I suspect it might be to uncomfortable for long distances. It's not a touring motorcycle, and it's suspension is a bit stiff to run on long distances.
Nov 10, 2008 | 2004 Suzuki GSF 600 S Bandit
Canon S2IS " change the batteries" problem
This worked for me after having the persistent "Replace the batteries" problem for about a year straight.
1. Reset the camera, according to the instructions in the manual. (Power on, hold MENU for 5+ seconds, selectOK, wait, turn camera off).
2. Remove the date/time battery for
two minutes (the tiny one in the battery compartment in its own little plastic holder). Replace after 2+ minutes.
3. Important: Insert freshly charged batteries into the camera.
I tried everything short of getting a new camera, and this was the ONLY thing to work for me. Its also simple enough that it takes 3 minutes to do, in case it were to ever happen again while on vacation, etc.
Good luck and I hope this helps.
Eric
Sep 27, 2008 | Canon PowerShot S2 IS Digital Camera
Canon S2IS PowerShot
Just try it with the canon service center.But this is a mnufacturing defect and they are not accepting it.They charge heavily for repair.
Dec 21, 2007 | Canon PowerShot S2 IS Digital Camera
I have the E18 error on a Canon S2IS
The lens needs a professional camera repair service.
The probability is high that the ultrasonc lens motor or th lens internal gears are damaged, and needs replacement.
Best regards
Nov 25, 2007 | Canon PowerShot A70 Digital Camera
Cameras Logo
147 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
