Question about Cyberhome CH-DVD 300 DVD Player
Cyberhome 300 dvd
I was messing around with the cyberhome 300's setup menu and i accidentally changed the video settings, i don't know how to change it back because i can't see anything... what can i do?
When I had this issue it was resolved by selecting the video input on the TV. For example: "S" video, RGB, etc. And of course check all of the connections.
Posted on Aug 15, 2007
SOURCE:
I have a (cyberhome ch-dvd 300) dvd player and changed setup menu now lost video cant see to change back is there a reset code or something
I wish I could find the website that gave all the repair hints for this DVD player, but I downloaded the info, and can no longer find the site. Here is what it says with regard to your symptoms. I hope this helps. I have done all the mods the site suggested, but continue to have difficulty with the remote, tray opening, etc. I have 2 machines and used to love them, but frustration has taken it's toll. Recovering from a condition with no TV picture
Accidentally switching to PAL and getting a rolling black & white picture happens all the time to baffle users, especially on models with a System or P/N key on the remote. To get back your color and sound just switch to the proper system in the menu or put in a movie of the correct type and it can switch automatically or try the procedure below for resetting to the defaults.
Sometimes owners will accidentally switch to Progressive Scan in the menu then get no picture at all. You can fix the no picture condition on the CH-300 by resetting the defaults to interlaced as mentioned in the users manual:
"To reset the VIDEO OUTPUT, turn Off the player, turn back On, open the disc tray and press and hold the Stop button on the player for 10 seconds to reset the scan mode."
The Reset procedure doesn't seem to work on all versions but you can sometimes get a usable B&W picture allowing you to get to the menu and change the settings by connecting the composite video input of your display to the Red Pr/Cr or Green Y component output jacks on the rear of the cabinet.
You can also go into the Menu and set it blind with the following key presses on the Remote:
1. With the unit Stopped, press Setup.
2. Press Enter.
3. Press the Down Arrow 3 times.
4. Press the Right Arrow Once.
5. Press Enter.
On 300Z & 300ZS models if the video is set to Progressive Scan and you can't get a viewable picture on the Red or Green jacks try going into the Menu blind and changing it back with the following key presses on the Remote:
1. With the unit stopped, press Setup on the remote.
2. Press the Right Arrow Once.
3. Press Enter.
4. Press the Down Arrow 2 times.
5. Press Enter.
6. Press the Up Arrow 2 Times.
7. Press Enter. This should switch it back to Interlaced scan with S-Video and Composite output.
To change the Parental Control setting on the CH-300 use the factory password of 3351. For the CH-400 use 1379.
Nov 02, 2009 | Televison & Video
I have a Cyberhome CH-DVD 300 and put it in progressive scan
turn on dvd player,leave disc tray close,press and hold in the stop button for five seconds,the dvd player will restore to factory settings and you will see the welcoming screen again,happy viewing watching your favourite dvds
Feb 28, 2009 | Cyberhome CH-DVD 300 DVD Player
Cyberhome Ch- DVD 300
Your advice was very helpful. After two+ months of tooling around and navigating around the menu blind I was on the brink of trashing it.
At first I tried the stop button with a dvd in the player with no success. After taking the dvd out, turning in off/on then pressing the stop button for 20 seconds the screen turned blue as said.
This help saved me a great amount of fustation.
Thank You!
May 27, 2008 | Cyberhome CH-DVD 300 DVD Player
Changed Video Output Setting
Reset you player by doing the following:
With the player on, hooked properly to your television1.gif, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 27, 2008 | Cyberhome CH-DVD 300 DVD Player
CH-DVD 300 Blank Screen
This is almost the same problem for me...Please provide a solution
Aug 16, 2007 | Cyberhome CH-DVD 300 DVD Player
No video
If you select Progressive Scan and your television doesn?t support it, you may end up with a blank screen and be unable to view the menu in order to fix it. If that happens, fix it by turning the DVD player off then back on. Open the disc tray, then press and hold the STOP button for five seconds.
Jul 24, 2007 | Cyberhome CH-DVD 300 DVD Player
No colour
Go to the setup menu. Change the output from NTSC to PAL. Should work.
Jan 22, 2007 | Cyberhome CH-DVD 300 DVD Player
Problem during 'setup'
I had the same problem too now my TV screen is all black and I can't do anything. can someone help please. thanks
Dec 13, 2006 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
97 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
