Question about Acer AL1716B 17" LCD Monitor
Unstable image my monitor has the horizontal shakes and i can't seem to find a fix for the problem. Some of the display is readable it's like every 3 inches or so the image is so shakey it is unreadable Any help would be appreciated..This is not a power problem or it is not too close to anything that would cause it. please help me fix it roknron
  • roknron Aug 16, 2007
    I have more monitors but this one is shakey.My other monitors all have great displays. I just wanted to use the lcd acer
  • 63 Answers
Have you tried installing a different monitor to your pc to actually find if this is a problem with the monitor or the video output of the pc? If this is not a viable option for you, you might try running a S Video or RCA cable from your video card to a TV and changing the output on your video setting to reflect such.
Posted on Aug 15, 2007
  • 1 more comment
  • Craig Nelson Aug 15, 2007
    Also, try a different cable as well.
  • Craig Nelson Aug 16, 2007
    Ok. Thats good. Make sure the frequency on the display is set to 60Hz. LCD does not like anything much higher than that.
    Is this a new monitor?
SOURCE:
LG L194WT picture problem
Sounds like your main board is going out. It's cheaper to buy another monitor then fixing it unless you have a warranty.
Feb 18, 2013 | LG L194WT 19" LCD Monitor
Blue vertical bar Left side and yellow,red vertical bars are seen both side of screen cause images are not readable
Hello
If the monitor displays these vertical bars, after a service has been done to it, and if LOT has replaced, there is a mismatching problem with replaced LOT and the defelction yoke.
Dec 18, 2011 | LG Studioworks 700S 17" CRT Monitor
"Lines" or irregularities through the monitor image display
Check power supply section for bad caps with bulging top first, may be a sign of failing power supply: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Jan 27, 2010 | ViewSonic VX2235WM Monitor
Screen image unstable
Sounds like your screen is set too big for your PC... it may just be a settings issue in your display properties. Right click on your desktop and go to properties, check in there and change resolution and things.
Doesn't seem like bad hardware.. just seems like a software setting is set improperly.
sorry i can;t be more help.
Sep 15, 2009 | Formac ProNitron 21/800 21 inch CRT...
Acer AL2216WBD LCD Monitor Problem
If your computer does not have a video card that supports the correct resolutions for the widescreen monitors, then your picture may get stretched. Much like watching normal tv programs on a an hd set. It will eitther strech or cut off the picture.
Try different settings in you computer display settings.
Fran
Sep 09, 2008 | Acer AL2216WBD LCD Monitor
HP 1730 lcd monitor horizontal glitches on screen. the monitor shows clearly but the screen shakes up and down until it enlarges itself of the screen so you can't see the task bar on thebottom the screen...
find the buttons on the monitor itself,  they control all those things.  I had the same problem myself.  It's not within the operating system --- it's the monitor itself.  It's not display control or any of those things
good luck
Jul 12, 2008 | Computers & Internet
Stripes on my Samsung Monitor
The contrast may be to high.
Adjust the brightness and contrast to make it go away but still readable.
if that does not help the FL (backlight) is going and the unit will need to be replaced.
Sorry.
Jan 02, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
AOC 17"
This seems like a leaky output capacitor. Trace the wire from the deflection coils (in the yoke) that leads to a fairly large electrolytic capacitor (usually less than 1000 uf, 220 or 470 uf and rated at more than 100 volts)Replace with new one. Electrolytics have limited lifespan. Take care when working with TV and monitor. Some large capacitor can retain charges even after the power is off. wait about 1 minute or 2 after pulling the plug before touching anything. Good luck
Feb 28, 2007 | AOC CT700G 17" CRT Monitor
Hansol 730E CRT monitor
REPLACE THE BOOSTER C 5,6nF-1600V
Oct 18, 2006 | Hansol 730E 17" CRT Monitor
Elongated desktop and software screen images
Many graphic cards enable you to rotate the screen up to 360 degrees. You could try to post this question again under you graphic card model instead of computer screen model as it is your graphic card that is certainly the problem.
Jul 25, 2006 | Microsoft ChiMei CMV938D 19" Widescreen...
Acer AL1716B 17" LCD Monitor Logo
238 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
