Question about Jabra BT500 Wireless Headset
Jabra BT500 won't power up
Hi, I just bought a supposedly new Jabra BT500 on eBay. I took it out of the package and plugged it in to the charger. While inserting the power plug the LED briefly lights up green but then goes out. I?ve tried just inserting the power plug part of the way in an effort to get the LED to stay green but nothing works. It just briefly lights up and then goes out. I've tried pressing the power button and all combinations of buttons but nothing happens. Is there anything I can do? The seller refuses to replace or refund my order. Is it worth opening up? What would I look for? Thanks John
  • Nik-at-night Aug 17, 2007
    I've tried charging with the USB cable too. No luck.
    I've already contacted the Jabra tech support. They will not support items purchased off of eBay because they assume they are counterfeits.
    I asked them if the problem could be a bad battery and if I could access it and replace it. The said "The battery is hard wired to the circuit board, and cannot be replaced."
    I can't figure out how this unit comes apart and I'm reluctant to attempt to break it apart accept as a last resort.
  • 944 Answers
If you can try a different charger, try that. try charging with USB cable if not. Try your charger on another headset if you can. I think the charger is the problem. If no change every way, here is the link to the user manual if you need it; http://www.jabra.com/Sites/Jabra/NA-US/pages/SupportProduct.aspx?productid=3c063d26-e62b-4b4d-9613-c10134a79cf3 Page 7 has the toll-free tech helpline which is probably worth a check in case they have any ideas before opening it up. If still no luck, and you want to open it up, first thing to look for is the battery. check any connectors are on properly. try charging for a while and see if battery gets warm/hot/no change. See if there are any technical specifications or part numbers written on the battery and I can get more info to see if it can be checked and if it is worth replacing. If you have any trouble identifying the battery, try posting back a photo of the inside and we will see what we can do. Hope this helps :)
Posted on Aug 17, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Aug 19, 2007
    Even if the battery is soldered to the board as they say, if you can use a soldering iron and if you can read a part number off the battery, then it can be replaced.
    As to opening it, couldn't find any specific info online, sorry - if you post back a couple of close-up photos then I can probably come up with some ideas.
    The type of battery that is probably inside is very unlikely to cost much so it is probably worth trying.
Is the rechargeable battery in the Jabra BT500 replaceable?
  • jabra headset battery swap - YouTube www.youtube.com/watch?v=MMLocSWjq8Q
    • BY THEDIECLAN2004
    • 3 MIN
    • 24K VIEWS
    • ADDED 2011-12-10
    Video embedded · jabra headset battery swap theDIEclan2004. Subscribe Subscribed Unsubscribe 15 15. Loading ... Plantronics Pro battery replacement - Duration: 9:15.
  • Jabra BT500 Bluetooth Headset - Newegg.com www.newegg.com/Product/Product.aspx?Item=N82E16826552001
    • 4/5
    • 69 REVIEWS
    Buy Jabra BT500 Bluetooth Headset with fast shipping and top-rated customer service.Once you know, you Newegg!
  • Jabra SPORT Bluetooth Battery Replacement - YouTube www.youtube.com/watch?v=Sm8cSkyTmfA
    • BY GREG PAJAK
    • 2 MIN
    • 27K VIEWS
    • ADDED 2013-09-23
    Video embedded · A quick video showing the ease of replacing the battery in the Jabra Sport bluetooth headphones. Jabra says when it it out of warranty they cannot be ...
  • Jabra BT-350 Disassembly and Repair - Instructables www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair Intro: Jabra BT-350 Disassembly and Repair. I wooted a few of these dandy devices a while back and they work great but the volume buttons are weak and the solder ...
  • Jan 26, 2016 | Jabra BT500 Wireless Headset
    Hello. I can't seem to get my phone to "discover" my bluetooth device.... Help?
    1. Turn headset off. Press and hold until solid light comes on.
    2. Activate Bluetooth on your phone.
    3. Search for Bluetooth devices and select Jabra BT500.
    4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 (4 zeros)
    Thank You
    Sep 05, 2010 | Jabra BT500 Wireless Headset
    My Jabra BT500 is on mute. Callers can not hear me. It worked fine at first now nothing.
    When powered up and in "talk" mode (during a call) hold the volume up and down "bumps" simultaneously. This engages/disengages the headset's mute function.... Hope this helps...
    Mar 08, 2008 | Jabra BT500 Wireless Headset
    Bluetooth help
    When you pair the bluetooth headset default passkey (PIN) should be used as "0000" (4 zeros). for further info you can check the user manual as I attached the link below
    http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT500/Documents/UM/BT500_UM_NA_EN_480.pdf
    Good Luck
    Feb 20, 2008 | Jabra BT500 Wireless Headset
    Jabra bt500
    yeah charge it for 14 hours......and then hold the pair and call at the same time... then repeat the pairing process
    Jan 04, 2008 | Jabra BT500 Wireless Headset
    Jabra BT500 will not power on or charge
    I would also like to know if you find a fix for this problem. I have the BT500 and it will also not turn on.
    Sep 17, 2007 | Jabra BT500 Wireless Headset
    Unit won't charge and I get no lights
    I have the same problem. it's due to a faulty pover-cell inside the headset. i have also read that the charger can be inserted the wrong way, this would in turn kill the battery by giving it a reverse charge.(not sure about that) as i tried this after finding the unit defective and it will only plug in one way.. the only suggestion that i can give is contact Jabra directly. iv'e read that they will replace any headset in this range for free, here is the address for their site. http://www.jabra.com/Sites/Jabra/UK-UK/pages/Contact.aspx Hope this helps.
    Sep 14, 2007 | Jabra BT500 Wireless Headset
    Jabra BT500
    the pin number is 0000, press and hold button until the light stays on to pair with your phone.
    Jun 04, 2007 | Jabra BT500 Wireless Headset
    Jabra BT500
    I had a very similar problem. Your headset is most likely defective. Call Jabra at Jabra.com and they'll replace it for you if you still have the receipt where you bought it from.
    Dec 03, 2006 | Jabra BT500 Wireless Headset
    Jabra BT500 Wireless Headset Logo
    245 people viewed this question
    Top Jabra Radio Communications Experts
    Bobby G
    Bobby G
    Damen Wong
    Damen Wong
    Jerry Greenberg
    Jerry Greenberg
    Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
