Question about Toshiba 32A43 32" TV
Volume go up to MAX, power button does not work
I have a Toshiba model 32A43, the other day, without any buttons being pushed, the volume suddenly went to maximum, the power button would not work, volume can not be turned down on the set or by remote, but the channels will change using the set's controls. After turning the power off at the power strip several times it finally seemed to reset. It worked fine for about a week and did it again. The buttons don't seem to have the same "feel" as when it was working properly. Can it be fixed? If so, about what should it cost to fix it? Should I toss it and get a new one?
  • 1 more comment
  • jimofswnh Nov 22, 2007
    My volume does just the opposite! Automatically decreases to -0- and after a while will respond again for a short time. The controls freeze up the same way. Just a guess but could it be a inferred receiver problem within the TV?
  • Anonymous Dec 02, 2007
    My tv does the same thing the volume will go up and down it is driving me nuts!!!!! anyway TO FIX IT??
  • Anonymous May 11, 2010
    I have a Toshiba 32A43 an di am currently having an audio problem, certain channels have no audio and others have partial. I cab hear the sound when the program is on and then when the commercials comes on the audio is gone( vise/versa). one day i'll have audio on a certain chanell and the next it's gone. Checked with the cable co. nothing there and other tv's in the house are fine.
    Novelist:
    Champion:
  • 232 Answers
To all of you, change the tact switches (all of them) on the front panel control board and end of problem, very common problem, part number for these switches is 23344443, any or several will become "leaky" and give all sorts of symptoms, MANY times this is caused by using windex or similiar type cleaners, it gets into the switches and corrupts them, this will fix-ya, BMW Rider
Posted on Dec 15, 2007
What is a tact switch and can i change it myself?
Posted on Mar 20, 2008
SOURCE:
Toshiba tv 32a43 changes input by itself
I will try to explain this: I first presume there is a physical button on the set for the input options.
I have seen this a lot:
Not the plastic button on the set but the tiny push switch behind it.
These are called momentary switches as only should function when the plastic button is pressed and contacts the momentary switch.
They go bad, and will internally engage without be touched.
The simple way to prove/disprove this is to open the set and get at that switch which usually is soldered into a small circuit board--two pins for the switch and maybe two more tabs for mounting.
If individual switches unsolder and REMOVE THE INPUT SWITCH (the one under the plastic button on the set)
Set should now operate normally and remote should have same feature on it. If it works you do not have to replace anything.
FYI: the reason the remote may not be working is the buttons on the set have PRIORITY over the remote.
Both the remote and the buttons go to the same area inside the set but buttons are #1 in line.
Dec 05, 2012 | Toshiba 32A43 32" TV
When we try to turn on the tv (toshiba model 32A43) it makes the sound of turning on then off and the screen stays black and a red light by the power button keeps binking
You're either losing high voltage or power supply is not producing the horizontal drive signal, Check for 130v on the collector of the horizontal output transistor, if you're missing your voltage, you have a power supply problem. If voltage is too high you have something open in the power supply such as a low value resistor. If its low, something is shorted in power supply, possibly voltage regulator ic.
Jul 31, 2011 | Toshiba 32A43 32" TV
Toshiba 32A43 - suddenly stopped responding to both my Toshiba CT-90157 remote and Verizon FIOS Philips RC 1445301 remote. Replaced batteries in both remotes & tried to reprogram the Verizon remote...
hi
this kind of problem is usely comming from one of the front panel button if so the set will show the menu intermitently and no action from the remote. What i use to do i replace
all of the tack switches 6or 7 but i would suggest to consult your local tv repair shop if
you do not have some kind of experience.
Sep 28, 2010 | Toshiba 32A43 32" TV
Model: 32A43 Problem: Volume goes UP automatically. Channel scolls automatically. I tried using the remote and the buttons on the tv panel but neither works. I tried turning the TV off with the remote and...
check the front button plate on the front of the tv very carefully.if it has been hit with something and either or any button is pushed in,it will not listen to other commands.make sure each button has a distinct click when pushed.a frozen button will cause other things not to work.it sounds to me like two buttons are making contact,and they are beside each other,so the button plate is crooked or warped.
Jul 18, 2009 | Toshiba 32AF43 32" TV
Toshiba (Model : 36A43) - volume goes down automatically
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
Jun 18, 2008 | Toshiba 32AF43 32" TV
Toshiba Cinema Series
possible regulator ic. in the power supply.
Nov 20, 2007 | Toshiba 55H70 55" Rear Projection...
My bush tv idlcd32tv22hd
Hi, You can try resetting the TV. In some other brands/models, hard reset is done by unplugging the TV from the mains for a couple of hours. Preferably check your owner's manual for more specific instructions. Good luck and kind regards.
Sep 28, 2007 | Toshiba 32A43 32" TV
Toshiba TV 35A44 Volume Issue
I had the same problem, you'll probably find that that particular button will push further into the set then the others, this is due to the a weakening of a cheesy metal guide which directs the projection off the back of the button into the corresponding microswitch. This metal guide will bend and will push against the switch.My solution, (and it ain't pretty) was to unplug the set, remove the button( I used a dremel cutting bit), locate the guide,a small metal plate with a hole in it. Bend the plate toward the front of the set then tape over the hole. I haven't had the problem since.You WILL have to use your remote for further functionality of the volume, However all of the buttons seem to be inherantly poorly designed and will weaken over time, AVOID USING THEM!
Aug 23, 2007 | Toshiba 35A44 35" TV
Menu won't stop popping up!
The first thing I would check is if any of the buttons on the tv has been push in too far including the menu button,if any of this buttons is making contact it will confuse the microcomputer and the rest of button become inoperable.Another possibility is corrosion in the buttons beacuse soemething has spill into them like pop or water.Check it out and let us know.Be careful,make sure set is not plug in.
Oct 06, 2006 | Toshiba 32A43 32" TV
Toshiba 32A43 32" TV Logo
489 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
