Question about Panasonic KX TC1703 Cordless Phone
No link to base
My hadset drpoed on the floor.Not broken.But always its complaining no link to base.Display ok, led lights in base ok, charging fine too,locator flashes but unable to reach handset .I have tried openning power, line, then connecting back, after 20 min charging no luck. Is there any way for this to force it to register with the base? Thanks
    Problem Solver:
  • 10 Answers
Check your handset.. reheat or resolder the components at pcb.
Posted on Jan 30, 2008
I have put new battery in the phone. When I coonect the powder, I have display on the hadset screen also the charge symbol is flashing. I have charged for 24hrs but it is still flashing! As soon as I took...
Firstly always use rechargeable Alkaline batteries. If your phone has been working prior to your change of batteries then the problem lies with battery contacts in the phone even when you place the batteries correctly. They are not clean. Clean them with a abrasive cloth. Now fix the new batteries and see if they are being charged. If still the problem persists then get the contacts checked up for any contact not functioning.
Has anytime the old battery busted/leaked inside the phone????
Feb 14, 2011 | Lands Phones
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
No dial tone on hand set battery is new lights up
Make sure your connection to the phone jack is secure.
Use another wired phone to make sure connection is good to your phone.
Secure connection in back of phone, and plug it in. The base MUST have power to transmit the signal to the handset even if the handset has a fresh charge.
Although the handset is normally linked to the bases, check to make sure via the instructions. To determine if the base recognizes the handset, press the "LOCATE HANDSET" button.
If the hadset responds, the links is there.
Hope this helps
good luck and don't forget to vote!!!
Sep 27, 2010 | Panasonic KX-TG2356 Cordless Phone
Not charging and no light saying it is
There is a possibility that the battery could not be taking the charge, but typically the light is red while charging and green when done. Sometimes if the is fully drained it can take up to 15 or 20 minutes before the red charging light comes on. Try leaving it charging for 24 hours.
May 05, 2010 | LG HBM210 Bluetooth Headset Wine Red Color
PHILIPS HEADPHONES SBC hc 8440
Hi there!
OK I know it is little late to response but if someone will google it, might find the solution, they are still selling it though. I just got my set as a xmas present so here is the way it works..
First plug the batteries into the headset, there is gonna be small power in it, however you have to charge it. So connect the small charging cable into the base unit and the headset and make sure the switch on the head set is off. Green LED light will appear on the base unit. Let it charge for 16 hours. After is charged you can unplug the small charging cable.
OK now how it works.
The base unit needs to be always plugged-in to the electricity supply. Connect the audio connector from the base to the e.g. TV, PC, DVD player, mp3 player... After you plug-in the audio connector red LED light will automatically light on the base unit.
There is is two channels what you can use, that's in case if you have two of the same wireless sets. So if on the base is set to # 1 the headset needs to be also on # 1. Then if you have second headset choose channel # 2 on the base and also on the headset # 2, so they are not crossing each other.
Now press switch on button on the headset and red LED light will appear. There is nothing wrong with the red light. That's just the way it is..
OK that's it. Adjust the volume on the headset and you should be able to listen to the music.. :)
Hope it was helpful.
Michal Bohucky
Jun 01, 2008 | Audio Players & Recorders
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Panasonic KX TC1703 Cordless Phone Logo
165 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
