Question about Samsung SCX 4521F All-In-One Laser Printer
Not printing I have trouble with my printer. It only prints when I open it. After a while of being open, it won't print anymore. The display says it's ready. The printer is the right one selected. I tried to reinstall the driver and the whole program twice and it still not working properly. It worked OK for a couple of months but when I replaced the original toner cartridge with a new one exactly the same number I started to have problems. I had it checked at the store where I bought it and was told it worked OK. I DON'T KNOW WHAT TO DO. HELP ME. THANKS
  • Mythos Mar 03, 2008
    I have the same problem. sometimes it prints ok. If it is not used for a while it wont print but itstill shows ready on the screen and everything looks normal. The only solution is to switch it off and then on again and it will print the pending document ok. It seems to me that this printer disables itself after a while and it must be "woken" up by switching it off and then on.
1) What Operating system are you using? 2) In Control Panel what is displayed for printers and faxes? 3)If, displayed select your printer and print a test page. 4)In device manager "compmgmt.msc /s" is your printer present?
Posted on Aug 15, 2007
SOURCE:
Everytime I open epson me office620f, it says "please wait" and will not be able to print or work anymore
My name is pramod Mahajan
My printer problem epson office 620 printer start now properly but send the print so printer display Printer error see yaour documention. so plese give me solution
May 24, 2014 | Epson ME OFFICE 620F MULTIFUNCTION INKJET...
Hp 2840 won't stop printing
power off the printer. removed the network cable only. power on until it display ready. now print a config sheet or menu map. if it print without error then connect the network cable and print config sheet again. wait and observed. if it will start printing garbage then KILL the print jobs queued on the printer. after deleting all print jobs power off and power on printer with network cable connected. I hope that will fix the problem. by the way. was there any error display in the panel display like "49.4C02". etc.
I’m happy to assist further over the phone at https://www.6ya.com/expert/gerardo_bdb2f65bdb2cdd4d
Feb 21, 2013 | HP LaserJet 2840 All-In-One Printer
Brother HL 5240 won't print after circuit breaker tripped while printing
It sounds like the power supply on the machine has blown sorry to give you the bad news
Oct 03, 2012 | Brother HL-5240 Laser Printer
Keeps printing copies of what i copied last week and won't copy what i want this week
((make sure you have the printer turned off)) otherwise you it might print another page if you have multiple prints in the queue you will have to open a file that you are about to print click ok a page will open with a display print queue tab you can see all prints right click on the ones you don't need select cancel
it will be in the print queue where you can stop it printing right click to delete what you are printing you might have to uninstall the printer then reinstall to adjust your print settings
or just go into your printers settings to alter/change the settings
hope this helps
Jun 12, 2011 | Computers & Internet
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
Won't stop printing
((make sure you have the printer turned off)) otherwise you it might print another page if you have multiple prints in the queue you will have to open a file that you are about to print click ok a page will open with a display print queue tab you can see all prints right click on the ones you don't need select cancel hope this helps
May 10, 2011 | Computers & Internet
Printer trouble
Find this in the web
http://h10025.www1.hp.com/ewfrf/wc/document?cc=hk&docname=c00489814&dlc=en&lc=en&jumpid=reg_R1002_HKEN
Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
Nov 29, 2007 | Office Equipment & Supplies
Brother MFC-210C
Do you use generic ink carts?
Please insert an original brother BK cart. In case the printhead is OK the machine should work again. If there is still trouble the printhead might be clogged and cant be fixed anymore due to wrong chemical additives within the generic ink!
When inserted the original brother ink cart run the powerpurge:
press menue then start b/w (blue button) then foutimes arrow-up button. Machine is within the maintanance mode. press 7 then 6 then 3. Display shows PowerP_All. Press start b/w (blue button). Machine runs power cleaning. Press 9 then 9  to leave the maintanance mode. Print a test print sheet.
Oct 25, 2007 | Brother MFC 210C All-In-One InkJet Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
