GoVideo DV2150 DVD Player / VCR Combo
Problem for GoVideo DV2150 DVD Player / VCR Combo
Bad disk
By amalamb on Aug 15, 2007
I was playing a movie and half way through the picture froze. I turned the dvd player off then back on and tried again but all it would say was bad disk. Now it won't play anything...all it ever says is bad disk. It is a go video dv2150. The same dvd diabled our playstation and dvd burner too so I know that the player daoesn' need to be cleaner (though I did try that anyways to no avail).
Same Problem
Feb 11, 2009
-   Inserted a disk. screen says its loading. continues loading but doesnt actually load the disk. sometimes will say BAD DISK and sometimes not. It happened al of a sudden during episode selection while the disk was readable and working fine.-   Guest
Jan 05, 2008
-   Have had this model DV2150 for a year or so without a problem until now. Any disc I try results in a BAD DISK message. Tried to use a dvd cleaner and the same thing. Now what?-   leo3254
Dec 10, 2007
-   Have had the same problem with two Go Video DVD/VCR players, DVR4400 and DV2150. Contacted the co.--will see what they offer as solutions.-   cameron342
Nov 30, 2007
-   Insert disc. get "loading" signal then "bad disc".,regardless of disc. Clean disc:no joy. removed casing. noted; disc sometimes will not spin unless finger started,then spins at erratic speeds, the part containing the laser that rides on rails jumps back and forth. tried cleaning the lense;no luck. Has only about 150 hours in it. Suspect it is a poorly engineered product.-   Guest
Best Solution
posted on Oct 30, 2007
Helpful)
pauldonp
Rank: Guru
Rating: 88%, 1267 votes
if this disk plays on other sources then it is not the disk and sounds like it is a problem with the laser or the motor that pushes the laser along the disk if it dont play no disk at all then it is the layser if you have used a good quality lense cleaner and that didnt cure it then you could try if you are ok taking the case off leave it for 24 hours to make sure no electric is running through it and look where the laser eye is it should be neer the middle where the center of the cd sits if it isnt gently push it back to the middle this will recalibrate your laser then put it back together and try again if this dont work you will then have to get a replacement laser unit these can be expensive but you should be able to fit it your self as the wire areconected by conector but before you do this make sure you use a good lense cleaner as the cheaper ones wont work all the time and listen if the cd is spinning in the unit if its not spinning then you need replace the unit if you dont feel up to it then a repair shop will do this for you their si no way round it other than to replaceit they usually last the life of the warranty they are made to last no longer hope this is some help but not much more you can do
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GoVideo DV2150 DVD Player /
Questions and Unsolved Problems for GoVideo DV2150 DVD Player /
Do you recommend GoVideo DV2150 DVD Player / VCR Combo?
Answer
Answer
I need to know how to connect this with my television (not an hd or lcd) the DV2150 and Time waarner... (More)
Answer
I tried to change to comcast remote, now want to change back. how?
Answer
I have a'' GO'',dvd/vcr,combination player. I use a basic hookup.(antennae cable right into the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Players Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
