Question about Maytag M7DH45B2A Dehumidifier
Missing hose adapter
Would like to hook the humidifier to a hose for drainage--so i don't have to empty it so often. but i can't find the hose adapter. where can i find one? thanks
  • 283 Answers
It might be a problem since these units were made by Fedders for Maytag which is now owned by Whirlpool :inhale: but I found part number FD9520-010 "drain hose". If not, a length of dishwasher drain hose with a male garden hose fitting on one end would work fine
Posted on Jan 15, 2008
SOURCE:
THe hose attached to the humidifier does not reain the bucket. Is there a plug or something I missed
No, you didn;t miss anything. The drain tubing inside the hose connection on the back of the unit may be clogged. To solve this problem, turn the unit OFF & unplug it. Then disconnect the hose from the hose connection.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hose connection & tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow.Reconnect the hose to the unit , plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor the hose end for water flow. It may take 10 to 15 minutes for the water to start flowing, so be patient. Also, be sure the hose you're using is no longer than 48". Drainage relies entirely on gravity.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
Hope this helped you to solve the problem. Thanks for choosing FixYa.
Sep 16, 2011 | Frigidaire FDL50R1 Dehumidifier
Don't see anywhere to hook up hose to the bucket? So that it will continously drain. Model HDN655E-rb
The drain plug should be on the rear of the unit about 1/2 way up the back of the unit. It has a screw off cap and rubber plug. Keep these & don't lose them. You will need them, whenever you stop using the hose drain. Most folks put them in the water bucket for safe keeping.
The garden hose can not exceed 48" in length and slope down and straight to the floor drain. Drainage relies entirely on gravity.
Hope this helps you and thanks for choosing FixYa.
Aug 27, 2011 | Haier HD656E Dehumidifier
What size of hose or tubing do I use to connect directly to my de humidifier, to drain directly into a drain. Thanks. I have model DDR451
A 48' long piece of garden hose will work fine. Connect the female hose connection to the unit's hose connector and be sure that the hose slopes down and straight to the floor drain. Drainage thru the hose relies entirely on gravity. Be sure to set the humidity extraction level low (32 - 35%) for continual operation.
I hope this helps you and thanks for choosing FixYa..
Aug 18, 2011 | Danby DDR451 Dehumidifier
Won't catch and empty water through attached hose.
My humidifier has a knockout inside the hose connection, that you have to remove. simple but check it out.
Jul 02, 2011 | Maytag Dehumidifiers
I want to add a drainage tube to the unit so I don't have to keep emptying the collection container. How do you de-activiate the "full bucket " switch? I have the Kenmore Model #...
Roren, once the hose is properly installed, it's not necessary to deactivate the bucket switch. Unless, the tubing inside the hose connection is clogged, the water should drain through the hose. However, the hose should not be longer than 5 feet and should drain down and away from the unit. As the drainage relies entirely on gravity.
If you have already tried this and was unsuccessful, the hose connection drain is clogged. You can use an 18" plastic Zip Tie, inserted carefully into the drain hole connection to loosen the clog and remove it. But, you'll have to gingerly work it past a bend in the tunbe, until it either bottoms out or you run out of usable Zip Tie. Then while pulling it back out twist the Zip Tie to dislodge the clog. As you reach the end of the Zip Tie, be prepared for some water to follow. Also, check the hose for clogs before connecting to the unit.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 10, 2011 | Dehumidifiers
With this model is there a way to attach a hose to it so that I can leave it running continuously while the hose is draining into drainage hole in my basement? m7dh65b2a
Yes, there is a way to do it. As a matter of fact, your model (now discontinued) came with a short section of hose. However, you can still use a short 5' section of garden hose and achieve the same results. To find the hose connection (if you don't have your Owners Manual) remove the bucket and you should see what looks like a hose connection (which it is) behind where the bucket sits in the unit. If it is not there, inspect the back of the humidifier for a small 2"x 2" pop-out compartment door. Inside of that is the hose connection. Remember, dehumidifiers do not have pumps to pump the water out, they rely on gravity for water to flow through and out of the hose.
Hope this helped you. Please let me know. Thanks
May 08, 2011 | Maytag M7DH65B2A Dehumidifier
Dehumidifier collecting water in container
If you have the hose drain tube connected, drainage will defer to it first. If you remove the hose drain tube, the place where it connects to the drain pan drips into the container instead.
Sep 17, 2008 | Maytag M7DH65B2A Dehumidifier
Drainage bypass to hose not working
I taped down the float in the container so that the unit would not shut off when the conainer filled up. The water now is going through the drainage bypass .
Oct 05, 2007 | Maytag M3DH30B2A Dehumidifier
Hose Drainage
yes, that is what the knockout port was designed for. Make sure the hose you get does actually thread onto the hose connection port before you punch out knock out. The hose should be a standard garden hose connector.
Aug 17, 2007 | Windchaser WDH928 Dehumidifier
Maytag M7DH45B2A Dehumidifier Logo
1,149 people viewed this question
Top Maytag Dehumidifiers Experts
Steve Allison
Steve Allison
Bill Long
Sr. Pelo
Sr. Pelo
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
