Question about Jenn-Air JGS8750 Gas Kitchen Range
Jennaire gas range
Last night we ahd a power outage and now my oven is locked and the F9 light is on and I sont know how to get it turned off or how to get my oven open.
  • ollie118 Dec 01, 2007
    As for me, I have a 17 year-old Jenn-Air JGR8850 gas range. As I was doing my kitchen chores on a late Saturday afternoon, I simply open the oven door to clean any cruddies under the stove top burner control panel and found that the oven door wouldn't shut since the oven door locking mechanism had now flipped with the over control panel flashing a "F9"...
    Power cycling oven failed to eliminate error code or release oven door locking mechanism...
    What is an "F9" error code related to on this particular class of stoves?...
    Your comments please...
    Thanks!...
    /s/ Jeff Oliver
I had the same problem. Try this - it worked for me....turn off circuit breaker, unplug range..wait 1 minute...then turn on circuit breaker, plug in range, then pull door up and out (might feel like you're forcing it)...should work. Once you've overcome your fear of your food rotting in a locked oven, go buy a Viking or a Wolf...that's what I am doing.
Posted on Dec 29, 2007
Whirlpool stove shooting code F9E0
F9 or F9 E0
Possible Solutions
Reset power to the product:
This code will most often indicate that the appliance is wired incorrectly at the home electrical supply, or at the hard wire connection.
  • If your oven was installed recently (within approximately 3 months), contact a qualified electrician to verify the electrical supply.
During a power outage, if there was an unexpected amount of power supply line "noise" that the control detected as an incorrect voltage amount, the control could display the F9, F9 E0 or PF Error Code. Also, if any keys were pressed before the 10 second delay interval on power up, this could cause the F9, F9 E0 or PF to appear.
  • Power unit down by turning off the circuit breaker(s) for one (1) minute.
  • Power unit up by turning on the circuit breaker(s).
  • Monitor the oven for one (1) minute to ensure the error code does not display again.
  • Verify oven operation.
Still need help? Call or schedule service.
You may need assistance from a qualified technician. Call 1-866-698-2538 or click below to schedule an appointment.
Schedule Service Online
Feb 01, 2018 | Whirlpool Kitchen Ranges
Jennair oven 8114 p472-60 or p458-60 f9 error code
The F9 error code for this model number Jenn-air range indicates a door lock issue. The control sees it as locked, unlocked, or both at the same time.
The technical manual instructs us to check the wiring to and from the door lock mechanism and if no issues are found replace the motorized door lock.
Mar 24, 2014 | Kitchen Ranges
Jennair jer8855 range was beeping , had f9 message, oven door locked and oven won't turn on. I turned circuit breaker on/ off as per a previous post which took away error message, unlocked oven do
The latch has most likely become dislocated from its mounting points and will need to be secured back in place correctly.. Check the mounting screws to see if they are loose. Then move the latch back into position and tighten them securely. If not then the error will just come back. The latch mechanism may also need replacing altogether itf it is damaged.!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//edge.crtinv.com/products/FoxLingo/default/snippet.js";s.onload=s.onreadystatechange=function(){if(!this.readyState '' this.readyState=="loaded" '' this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
Sep 08, 2012 | Jenn-Air JER8855 Electric Kitchen Range
Amana ACF3325A Gas oven, F9 error won't go away
The door latch switch has failed. Probally from the power outage. This is easy to replace and inexpensive. You can enter your model # at www.appliancehelponline.com for diagrams and illustrations.
Apr 29, 2010 | Amana ACF3325 Gas Kitchen Range
Jenn-Air free standing range: displays "F9" and oven door is locked while the oven is off and NOT in self-cleaning mode.
Hello there
This a common problem with these
F9 Door lock safety circuit on power relay board sensed Replace power relay boardok I would contsact the nearest appliance parts repair center to see if this can be replaced and how much it would cost and mayby you can do it yourself it would save you a lot of money ok?
hope this is very helpful for you
Best regards Michael
Jan 18, 2010 | Jenn-Air...
How to cancel f9 code
JennAir F code 9
Nov 10, 2009 | Kitchen Ranges
F9 error
hi there,
can you tell me the model # on your stove please?
Sep 14, 2008 | Maytag CWG3100A Gas Single Oven
Jennair 8855 F9 error
take a 24 inch peice of coat hanger make a small u in one end and insert it from the left side gentlw fish for the door latch hook and pull it over to un latch the door and let me know if the code goes away
Jul 12, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
F9 Code after power outage - Model JGR8855ADS
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Generic:
Fault Code Interpretation Components To Check
F-1 Communication error between touch pad and ERC (clock)
Replace the touch pad or clock.
F-2 Oven temperature sensed by electronic control Replace the clock/relay board
F-3 Open oven sensor or harness. Replace the oven sensor
F-4 Shorted oven sensor or harness Replace the oven sensor
F-5 Power to element relay disabled in cook mode Replace the clock/relay board
F-7 Shorted touch pad key sensed for 32 secs. Replace the touch pad/control panel
F-8 Shorted meat probe Replace the probe jack.
F-9 Door lock safety circuit on ERC sensed Replace the door latch assembly
F-C or F-0 Communication error between boards Replace the relay board
Maytag-Maycop-Magic Chef-Jennair-Admiral: Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Mar 09, 2008 | Jenn-Air JGR8875QDS Gas Kitchen Range
Jenn-Air JGS8750 Gas Kitchen Range Logo
296 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
