Question about Sony Handycam DCR-HC20 Mini DV Digital Camcorder
LCD touch screen
The touch screen does not work. I went to the calibration screen and pressed the "x" like the manual told me but it did not do anything.
  • enmanuelpm Jun 15, 2008
    could you sell me one of these cables or tell me where I can buy it because I need one and I dont know where I can get it. Thanks
Take off the screws at the left side of the lcd screen, than open gently the case. Use a air can than spray for cleaning. The lcd screen is now back on duty...
Posted on Mar 04, 2009
model no.------dcr-hc19e pal
Posted on Nov 13, 2008
  • 169 Answers
There a open flex wire through the touch screen control...it is need to be replace the wire to the sony service....in our shop we modify that wire and it became more durable....try to other service center if they can fix the flex wire....
Posted on Aug 15, 2007
  • Mimi May 30, 2013
    Hi, I came across your message on LCD Touch Screen flex cable... I have a Sony DCR-DVD505 handycam and the touch screen stopped working after sitting in the storage for a while... Everything seems to be working fine, but there's no way to know unless we can view it from the screen. Is the flex cable the problem? If so, do you have the DCR-DVD505 Flex Cable available? Otherwise, do you know where I can get it? Thank you so much!
Touch panelany not working properly. Any command can not be used.
Posted on Jun 10, 2011
I have a Handycam digital video camera recorder- DCR-HC30. The camera sat in its carrying case at room temperature for about two years without being used. When I went to use it, the touch screen would...
The LCD / Touchscreen module is no longer available from Sony for this Model. However, I have a limited supply of them.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Feb 08, 2011 | Sony Handycam DCR-HC30 Mini DV Digital...
DCS T70 LCD does work properly .I mean to say if i try to use one function another function gets started instead of desired function
Based on the information you've provided, it seems that the touch screen panel is not aligned. You can try Calibrating the touch screen to resolve the issue.
Calibration option is in the Main Settings 1 Menu of the Camera. Calibration option enables you to perform calibration when the touch panel buttons do not react at the appropriate points where you touch. You can use the paint pen, touch the X mark displayed on the screen. The X mark moves on the screen. Once the calibration option is finished successfully, the touch screen should work.
The Calibration option can be done only if the Menu is accessible.
You can also perform a power reset before performing the Calibration.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
This should resolve the issue.
Thanks for using Fixya.
Jan 10, 2011 | Sony DSC-T70 Digital Camera
Sony dcr-hc26 touch screen does not work
If the touch screen of the Camcorder is not working, pleasefollow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
dcrhc26%20reset%20button.jpgdcrhc26%20reset%20button.jpgmoz-screenshot.pngmoz-screenshot-1.pngrsshajan_3.jpg
Note: 8 represents the reset button on the above figure.
If the issue persists again, please perform LCD screen Calibration and check ifthat helps.
Please follow the steps below to perform the LCD Calibration
If the issue persists again, service is required.
I hope this information will help you to resolve the touch screen issue of theCamcorder.
Dec 30, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
The touch screen is not working. After resetting
If the buttons on the touch-panel LCD screen do not respond correctly or do not work at all, adjust the LCD screen calibration. Consult the instruction manual if specific information is required to perform this procedure.
NOTE: The touch-panel LCD screen cannot be calibrated if it is rotated.
Aug 08, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
DCR HC20 The touch screen does not work. I went to the calibration screen and pressed the "x" like the manual told me...It does not work too, Please help
I believe the flexible cable from the LCD screen to the main control was cut or lose because the action of open and close the LCD, in any case It require a qualifier Tech trained from Sony to replace this FC
DO NOT tampere it, You might damage the LCD screen
Dec 09, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
Touch screen on handycam dcr-hc30
There is a flexible cable between LCD and Camera circuit may be cracked/ broken. Replace it and touch screen will work fine.
Jun 12, 2008 | Sony Handycam DCR-HC30 Mini DV Digital...
Touch LCD points not opeating properly
How often have I heard the phrase - Read the Manual - however I admit to a slight case of panic as I have an important bit of videoing coming up soon....however as the Manual says... The solution to LCD touch screen hotspots not working is re-calibration.
With the Sony DCR-HC22E (also the HC17E/HC19E and HC 21E still Digital Camera this is achieved by
Eject the Tape
Disconnect any Connecting Cables except AC Adaptor or the Handycam Station
Slide the Power Switch Down to turn on the Play/Edit Lamp WHILE pressing the Disp/Batt Info for about 5 seconds
You should then get a screen with a cross in one corner
(The manual recommends touching this with the corner of a memory stick however I GENTLY touched it with a biro. In my case a further 2 crosses appeared and after touching them the LCD Was Re Calibrated.
I re-started my Camera and all the touch spots ( Fast Forward, Menu etc all worked perfectly) Remember you cannot Re-Calibrate with LCD rotated
May 25, 2008 | Cameras
Touch Screen not working
ı have problems about wıth my touch screen. ıt does not works sometımes.
ı have to restart my phone to make ıt work . can ı do somethıng more?
Apr 21, 2008 | LG KU990 Viewty
Touch panel menu unaccessible
Me too! The camera was working perfectly until yesterday and when I turned it on today, it selectively ignores some buttons on the screen - and pressing the "Menu" gives me nothing. I've tried to reset it through that pin hole button, but it just resets the machine back to its default.
Dec 13, 2007 | Sony HDR-HC1 Mini DV Digital Camcorder
Sony Handycam DCR-HC20 Mini DV Digital Camcorder Logo
2,379 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
