Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool refrigerator making noise
When the fan goes on in the freezer, it sounds as if a helicopter is in the freezer. A repairman said it might be ice build up on the fan. I have defrosted the freezer and this seems to work but now it seems to do it every day. how can I keep this from happening. I don't even keep food in it because I have to turn it off everyday.
  • macungierb Apr 23, 2009
    when opening doors a sqeaking sound accures
  • Whirlpool Master
  • 909 Answers
YOU HAVE AN ISSUE WITH THE DEFROST CIRCUIT. NORMALLY BOTH THE DEFROST COMPONENTS NEED TO BE REPLACED. NOT OFTEN DOES THE DEFROST TIMER GIVE TROUBLE SO IF BOTH COMPONENTS ARE REPLACED AND ELEMENT IS GOOD BUT ICE STILL BUILDS UP THEN TIMER WILL HAVE TO BE REPLACED AS WELL.
Posted on Aug 24, 2007
SOURCE:
Whirlpool gold French doors freezer in the bottom it's making a knocking or rattling sound like it's coming from the back panel in freezer open freezer it stops close it starts
SOUNDS LIKE YOUR FAN MOTOR IS EITHER LOOSE OR THE MOTOR IS ABOUT TO GO OUT(NOISE INSIDE COULD BE GEAR IN MOTOR GRINDING WHILE WORKING) it stops when you open the door which shuts off he fan motor to help prevent loos of refrigerated air.
Dec 04, 2016 | Whirlpool Refrigerators
Why do the freezer coils on my Whirlpool stainless steel model GB2SHDXTSOO ice up?
I posted the problem with my refrigerator that started this thread. I had a repairman out to fix the refrigerator. He replaced the defrost thermostat. About a month later the coils iced up again. I called the repairman back. He said he wasn't sure what the problem was, but he would do some research and get back to me. Two weeks later I hadn't heard from him and he wouldn't return my calls. I finally called another repairman and he came out today. He said the Captain Board is bad. It has a relay sticking. He turned the refrigerator and freezer off, but the refrigerator still kept making noises. He said one of the noises was the damper valve opening and closing, but it shouldn't be because he had turned the refrigerator and freezer off. He listened little longer and asked me if I could hear the humming sound. He said that was the compressor, which shouldn't be making any sounds because everything was shut off. He said the Captain Board costs about $220. Does any of this sound logical
Mar 14, 2013 | Whirlpool GB2SHDXTS Stainless Steel
Freezer makes intermittent fan noise
one time i ran into this problem and found out the lady was putting hot things in the freezer creating alot of moisture. check your door seal also make sure its sealing if it had gaps you can heat it up with a hairdryer to streach it out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Mar 28, 2010 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Temp is rising and fridge is making noise
the problem lies with your evaporator fan motor, ice is forming underneath the fan blade, and as one customer told me, it sounds like a helicopter. when this fan stops altogether, no air flow to fresh food section is a result.
the cause could be the fan motor itself is bad, or if there is ice underneath the fan blade, the defrost drain is clogged with ice. after clearing the drain, i would highly suggest putting a defrost drain heater, to prevent ice build up in drain,, from obstructing fan blade. You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | GE Profile PDS20SFS Bottom Freezer...
Whirlpool model ED5FHAXSLOO refrig 3 years old very noisy
If it is cooing fine, then the noise is probably your evaporator fan (the one inside your freezer). This can be cause by one of several things. The motor on this fan may be going bad, or, more likely, you may have a build up of ice around the blades that are touching the fan. This may be caused by a defrost circuit that has gone bad, or, the freezer may have been open alot lately and there is an excess of frost that hasn't melted away yet. If you can, manually defrost the freezer and see if it goes away. If it doesn't, it's probably the fan motor. If it does, and then comes back, it's probably the defrost circuit. Hope this helps!
Dec 06, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Making a loud noise
yes. is the fan hitting ice. the fan activates when close the door the upper baskett press the fan and light switch............... good luck.......... LEAVE YOU COMENT IF IT WAS GOOD FOR YOU
May 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Very loud noise whirling sound
Can you tell me where the sound is coming from? Like inside freezer or under refrigerator. Most sounds like you describe come from a fan motor and the fan blades are hitting something. Let me know, Thanks, Sea Breeze
Apr 23, 2009 | Whirlpool ED5FTGX Side by Side...
Inside back of freezer making a loud noise like a horrable vibrating noise. whirlpool side by side ED22TQXGW00 sounds like something is vibebrating real bad it's a whirlpool sj2446090 model ED22TQXGW00...
Hello the fault is most likely to be the defrost system building up frost around the fan and causing the bad sound to prove this just turn off freezer for about 10 hours to defrost and restart if noise has gone away then your defrost system is faulty
Apr 07, 2017 | Whirlpool 21.8 cu. ft. Side-By-Side...
New refridgerator delivered this morning to replace the same model that was a lemon. The fridge is making a sound on the fridge side. When I open the door to the freezer side the sound stops. When I...
sounds as if there is an issue with the evaporater fan motor, perhaps the fan blade has come dislodged and is makinf noises, normal for the fan to stop when the frig door opened as welll,
Dec 17, 2008 | Refrigerators
Freezer
I have a GSL25JFPH BS refrigerator by GE. It made the whirring sound, a repairman came out and told me that the fan motor needed replacing, price of $277. I sent him away, and after a few minutes on the internet, saw on this site that a new circuitboard (part# WR55X10656) should fix it. I found it on ebay for $83, and it took about fifteen minutes to install. No more whirring!!
Oct 31, 2007 | GE GSL25JFPBS Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
1,530 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
