Question about Brother ML-100 Typewriter
Types incorrect characters
I have checked the print wheel, and performed the [code]+[reset]. Most characters print correctly except for the following: f=@ j=[ v=# !=$ @=v #=& $=* (=% )=( -=/ _=? J=f. Any help would be greatly appreciated!!
  • jpvande Aug 15, 2007
    It was working fine last time used, I don't know how the switch got changed, but that cured it - thank you very much!!
  • Deb Raymer Mar 28, 2009
    all the letters print correct except the J prints an f and all the letters you have to shift for the second character are wrong when printed.
  • 328 Answers
Have you checked the keyboard switch inside on the right. The US setting is the selection to the rear.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 15, 2007
SOURCE:
Typing the wrong letters
First try opening and closing the top cover. If that does not reset the print wheel to the correct characters, check and make sure the correction tape is not interfering with the wheel as it spins. If that is not the case remove the print wheel and make sure non of the spokes are bent. If they are you can try bending them back to the right position or you may have to replace it.
Jan 17, 2012 | Brother GX-6750 Typewriter
Whem keys are typed incorrect display of characters. how do i correct it?
REMOVE & RE-INSTALL THE DAISY WHEEL, MAKING SURE THE HOMING PIN IS IN THE HOLE NEAR THE HUB OF THE WHEEL. IF IT STILL DOESN'T PRINT THE RIGHT CHARACTERS, THE PRINTWHEEL MOTOR OR MAIN BOARD COULD BE BAD. TOSS IT AND BUY ANOTHER MACHINE
Aug 18, 2010 | Brother SX-4000 Typewriter
Incorrect character printing.
On the L. side of the keyboard is a slide switch labeled 15, 12, 10 and PS it is probably in the PS position. If it isn't then slide iy up snd down a few times they do get dirty.
DickyO
Mar 26, 2010 | Nakajima AE-830 Typewriter
Daisy wheel seems to be typing wrong characters. Is there a correct orientation for the wheel the typewriter? thanks Anne in Espanola Brother sx4000
type "code" and "reset" it will reprogram itself and get the wheel lined up properly to be correct with the keys you type.
Mar 31, 2009 | Brother Office Equipment & Supplies
Incorrect characters printing after the third line
Geno111 doesn't know what he's talking about. Look closely at your correction tape once it has passed the daisy wheel. Does it looked roughed up a little? I just had this same error and discovered that my daisy wheel was hitting my tape when spinning and not allowing it to jump characters like it needed to. I simply put a little double sided tape on the daisy wheel cover between it and the metal tab that holds the ribbon at a certain distance, to increase the space the daisy wheel has to spin. It seems to have worked so far. If anyone has a permanent solution, or answer as to how it spins wobbly, I'd love to hear it.
Nov 18, 2008 | Brother ML-300 Typewriter
Wong letters & numbers
I downloaded the manual from http://www.devicemanuals.com/downloadguide.php and then, following the instructions there, I removed then re-inserted the daisy wheel. This solved my problem. Perhaps it had somehow gotten out of adjustment. At least, it is something to try if you haven't tried it already.
Jul 15, 2008 | Brother GX-6750 Typewriter
Possessed typwriter
Assuming that you have the correct print wheel fitted and that the typewriter is on standard key board setting then I would look at anything that might be interfering with the rotation of the print wheel. First, remove the print wheel and check that none of the character arms are distorted,then look at how the correction tape is fitted. If this tape is not fitted correctly it could be interfering with the rotation of the print wheel.
Nov 02, 2007 | Brother SX-4000 Typewriter
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
Print Wheel Drive Gear is out of Positoin
Normaly this would not be a user adjustment, possibly the grub screw hold the wheel hub to the motor has come loose, very small allen key needed, you make be able to shift it back to right place. Usualy this is done with special alignment jig
Aug 02, 2007 | Smith Corona Wordsmith 200 Typewriter
Types wrong Characters
Does it always type the same wrong letter ie a always prints u or w ? if so the print wheel drive gear is out of position. if not and it get random letters some thing may be interfering with the wheel rotation.
Jul 04, 2007 | Smith Corona Wordsmith 200 Typewriter
Brother ML-100 Typewriter Logo
166 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
