Question about Acer Aspire 3000 Notebook
Help! No power.
I can not get my laptop to power up. I have it plugged in but the battery won't charge and it won't power up. I even bought a new cord thinking the old one shorted out but the new one won't work. Help!
Your dc jack is failed and needs to be replaced. You can go to DCJACKREPAIR.NET and pay $125 fixed price to have the jack repaired/replaced
Posted on Aug 21, 2007
    Problem Solver:
  • 11 Answers
Remove your battery, then use only the AC adaptor, if is the same the problem is from your Mainboard/ check to supplier if is still warranty. So that you can claim for it.
Posted on Aug 15, 2007
4 Suggested Answers
SOURCE:
RescueTechLA
  • 2653 Answers
SOURCE: Charger plugged in and computer says it's charging...but it's not
Return it! It's a factory defect they just admitted to it online. Call HP and they'll fill you in on the details.
Posted on Feb 20, 2009
  • 51 Answers
SOURCE: My Acer Extensa 5420 laptop won't charge. I t
Could be down to a few things. First it is worth checking all the connections and making sure they are good and clean.
Im presuming that if it wont charge, it dies when you disconnect from the mains? If not let the battery die completely and then recharge fully. Discharging, Charging & discharging is also an effective method of calibrating the battery
If the battery gets hot while plugged in, you should remove the battery and allow everything to cool down (some systems have a CMOS setting to prevent over charging, this can take 3-5 days in a cool environment to unlock the battery)
Have a look at the power options in the control panel and make sure everything is reset to default settings.
I once disable hibernate option for a troublesome dell and this allowed the battery to take a charge.
A more aggressive route is to check the bios settings and check if you need to update
It is worth noting that if the laptop is new (or still in warranty) bring it back, it could be a faulty battery, which is not unheard of!
Posted on Feb 17, 2010
  • 62 Answers
SOURCE: Acer power cord
if you can use your notebook without the battery with the power cord attached, then the battery ist defective. If your notebook doesn't power on at all without battery, then the power cord is faulty.
Posted on Jul 23, 2010
Lenovo idea pad won't charge or run plugged in
Is the cord and Battery the EXACT same power spec? If so, it may be the AC jack in the Laptop has been damaged due to pulling on the cord while plugged in, broken connection.
Apr 06, 2013 | Lenovo IdeaPad Y450 Notebook
Battery won't charge
So put the old power cord back on since you say it charged the battery normally. Why did you change it if it was charging the battery? It's quite possible that the new power cord is faulty. Just because it is new does not mean it works.
Remove the battery and plug the new power cord in. Does it boot the laptop up? Are you able to function with the new power cord plugged in. If so, then your battery is more than likely dead and needs to be replaced. The battery only has a useful life and once it is completely bad it will not charge.
May 01, 2012 | Dell Inspiron 1545 Notebook
New battery HP g61 is fully charged but not working \
Maybe the AC Adapter Power Cord is not working. If you can't get on the laptop with the power cord then it is bad and the battery might be drained so you have no power source to power up the laptop.
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 30, 2012 | HEWLETT-PACKARD HP G61A50US 156 AMD Athlon...
Samsung r510 battery not working
New Battery will not charge? So will the laptop power on with just the Power Cord plugged in? If no, then the power cord is bad, no wonder the battery won't charge.
Mar 31, 2012 | Computers & Internet
How do i get my laptop to power on? Have new power cord but still will not power up
There is a possibility that if the battery is shorting out it won't hold the charge or let it power up.
Mar 30, 2012 | Toshiba Satellite L455D-S5976 Series...
My Asus Eee PC 1001PXD battery won't charge. The charges light is on but nothing happens and now the battery is completely dead and I cannot get my notebook on
Your problem is far more than the battery. Your problem is the power cord. Laptops for the most part will work off the power cord even if the battery is dead or even if the battery is not in the laptop. Your power cord charges your battery and if it is bad it will not charge it. You've been working off your battery even though you might have had the power cord plugged in, but if it's bad and not charging the battery, the battery drains and then you can't get the laptop to power on at all. Go purchase a ac adapter and power cord that is designed for your system. Don't buy one that some of the big box stores sell that has a an interchangeable plug at the end designed to fit just about any laptop. Those will eventually burn *********** board out.
Mar 20, 2012 | ASUS Computers & Internet
ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE BATTERY PLUGGED IN THE POWER CORD WON'T CHARGE THE BATTERY ALL THE TIME ...
Hi: Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link: http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Sep 25, 2011 | Acer Computers & Internet
ALIENWARE DESKTOP LOST ALL POWER
In a laptop, you can lose power in three ways.
1. Dead battery 2. Dead Power cord. 3. Bad motherboard.
ther first two should be rather obvious, as the battery won't work or it won't hold a charge, but if it won't turn on at all, even while plugged in, chances are that you're going to need a new motheboard. This can be expensive in the M--x laptops, unfortunately.
Sorry for the bad news, mate.
Apr 29, 2011 | Dell Alienware M11x Gaming Laptop Computer...
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
Acer Aspire 3000 Notebook Logo
125 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
