Question about Onkyo TX-SV525 Receiver
No sound in surround modes
Sound is apparently "normal" in by-pass mode, but from the front speakers only. No sound from any speakers (2 fr, 2 rear, 1 ctr) in any surround mode from any source.
  • 3 more comments
  • bilbobolson Feb 03, 2008
    I just connected the front main speakers and sound well, but when i connect the speakers (2 fr, 2 rear, 1 ctr) there`s no sound in any
  • dietrich804 Feb 09, 2008
    I have the same exact problem. I have fiddled with it repeatedly. I bought mine used and had similar problems hooking it up the first time. Until I talked to an old-school theater guy who told me how to hook it up correctly. This problem is new. It stems from my daughters laying in front of it and kicking it with their feet. I just can't figure out what button they kicked.
  • omarts Jun 05, 2008
    I have the same problem with TX-SV525. I'm watching movies in surround mode and suddenly the sounds goes off. Tried to check all cable connections and looks fine. Also, tried to reset factory setting but no to avail. The receiver is now working only in BY PASS mode (Front Channel Speakers).
    Does anyone know to fixed this problem? I would apprecaite if you can provide info to fix it.
    Many thanks,
    omarts 12
  • art8457 Jun 08, 2008
    I am having a problem with my Onkyo TX-SV525 where I have absolutely no sound coming from my speakers in surround mode and when I by-pass, I only have sound coming from my front L & R speakers. I haven't changed any of the settings on the receiver, and I have verified all connections are secure. I even strung new speaker wire to no avail! The only difference is that we purchased a new TV, but everything is hooked up according to all the manuals (the receiver, DVD player and the TV). It seems the surround simply stopped working. Please help - I love to watch movies in surround, and it's just not the same without it. Does you have any advice or ideas I can try?
  • Anonymous Jul 21, 2008
    yes
I just connected the front main speakers and sound well, but when i connect the speakers (2 fr, 2 rear, 1 ctr) there`s no sound in any surround mode from any source.
Posted on Feb 03, 2008
Surround sound
there are 2 channel modes on your reciever, as well as surround modes, and it sounds like you have changed modes by accident. just open the little door on the front, and take it out of 2 channel mode
Mar 05, 2013 | Denon AVR 2808Ci Receiver
Lg lht854....wont play sound out of rear and center speakers
Try setting it first on surround mode because it is normal for the rear speakers not to come on when it is the surround mode is off. For the center speakers make sure it is hooked up properly. Follow the instruction if you have one. Lastly I never heard of center speakers have two speakers in it but if it does and you only have one set of wire to it then one of the speakers is no good.
Jun 26, 2010 | LG LHT854 Theater System
Sound only some out of 2 speakers at a time. I need all 4.
Here you go buddy:
http://www.docs.sony.com/release/STRDE685.pdf
May 19, 2009 | Sony STR-DE685 Receiver
I only get sound out of 2 front speakers with 5.1.
refer owner manual page 46-51, try different surrounding sound modes.
Apr 08, 2009 | Sony STR-DG510 Receiver
My Onkyo TX SV 535 Surround Sound wont work
Speaker relays have oxide on the contact points. Open up all the speaker, spk, relays and remove the oxide layer formed on the 12 contact points. Those 3 relays are on the spk terminal board. You can located it easily. It just mounted next to spk output, a horizontal board.
Aug 13, 2017 | Onkyo TX-SV535 Receiver
when the stereo or mono listening mode is selected only front speaker and subwoofer produce sound--------make sure that speakers are configured correctly.
and you select surround sound in listening mode.
Aug 17, 2008 | Onkyo TX-SV535 Receiver
How do i hook up Altec Lansing AVS500 speakers to my computer
Hello sweetnikki1,
The Altec Lansing AVS500 are 4.1 channel speakers, meaning 4 speakers (front, rear and 2 satellites) and a subwoofer.
1. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the satellite cords are similarly color coded. The output from the sub to the front right satellite is a heavy-duty cable that immediately stands out from the rest. This cable is thicker because the right front speaker has most of the system controls on it: power, volume, and surround volume. If you do not have a surround sound card, make sure you obtain the proper adapter or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, on the left side are the sub level control, the AC jack, satellite outs, and a sound mode switch. With this switch you decide between Gaming and Stereo. In Stereo mode, the normal stereo signal is sent to both the fronts and the rears. In Gaming mode, the speakers use the four-channel signal from your soundcard. Hence if you just hav the regular sound card, do not connect the satellite speakers and use Stereo mode.
3. You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
Hope this helps..
Should you have any further questions, please feel free to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further, if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FixYa! rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Apr 20, 2008 | Computers & Internet
Logitech x540 speakers- rear speakers distorted on matrix mode
I installed my soundcard which is the sound blaster SE audigy but when i try to test the sound i see that it does not sound separately.What i have to do to make them sound saperately when i'm testing it ?
Apr 16, 2008 | Logitech X-540 Computer Speakers
830 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
