Question about EMC CLARiiON AX150 (AXS207500KIT) Network Storage Server
Slow file transfer
Users complaining of very slow file transfers from SAN. Server is Dell dual-core, dual proc Xeon with 4GB RAM, running Server 2003 SP2. Downloading a 500 MB file can take hours.
    Problem Solver:
  • 19 Answers
What is your connectivity to the SAN? fiber or iSCSI? Have you checked the management tools to see if there are any errors on the data paths? If using iSCSI and the SAN and server are in the same network segment, make sure the default gateway is empty for the iSCSI connection. Look at the routes on the server to make sure the traffic is not leaving the subnet through a router and back to the SAN, and vice versa. If fiber then you'll have to use the tools given to check for errors. Ken
Posted on Aug 15, 2007
SOURCE:
I want to install windos 2003 server on dell poweredge 2600 but the server is very slow i want help
I am not sure what you mean by "slow" so I will anwer in general terms. I would recommend 1st that you make sure the PowerEdge meets the recommended hardware specs for Windows Swerver 2003. (Memory, CPU speed, Hard drive capacity, etc.) 2nd- I would run two Xeon processors instead of one and add as much memory as you can put in your system.
I run MS Server 2003 on one of my servers and here is the configuration that I am using:
2 Xeon 2.8GHz processors
6GB ECC Memory
120GB hard drive for the server operating system (Nothing else is on this drive)
750GB hard drive for all other applications
External NAS storage for files, data, etc. (connected to my netword via Ethernet 5e)
With this setup, my server has been running very well for 6 years now. I do maintanance every week on it to keep it up to par. (Simple dusting, checking cables, etc.)
Good Luck.
C2Solutions
Sep 11, 2011 | Dell PowerEdge 2600 Server
Just built new computer using an ASUS Z8PE-D12 motherboard. When I power it up, it keeps wanting to flash the bios. I just had to replace an identical motherboard doing the same thing. Removed all...
z8 is nice, I know for sure,
Z8PE-D12 the dual xenon server grade mobo, like my z600 works station has but HP made.
let me guess both boards never worked for you and you bought them on fleabay, and are DOA? that it, what is the story here.
Let me guess more, (no history at all)
you just put in a new CPU, xeon, ?
well if you did and
1: it is not support, it will do that.
2: or it needs flashed bios to support newer xeons.
3; no you can not run all xeon's made in this mobo ever.
first off put only one xeon the primary socket.
and only ram for just it.
then at ausu we site makes sure you are using the right xeons first.
the correct path is with working xeon, flash the bios.
then upgrade xeons last.
ok?
5500 series processor
1366 socket
Six-Core/Quad-Core Intel® Xeon® X5600 Series (130W)
Six-Core/Quad-Core/Dual Core Intel® Xeon® E5600/E5500 Series (80W)
Quad-Core Intel® Xeon® W5500 Series (130W)
Dual Core/Six-Core/Quad-Core Intel® Xeon® L5600/L5500 Series (60W/40W/38W)
Six-Core/Quad-Core Intel® Xeon® X5600/X5500 Series (95W)
here is the offical list.
newest BIOS is 1401
i bet yours is super old bios and not stated, or what xeons you have.
as you can see it is not trivial this topic.
https://www.asus.com/Commercial-Servers-Workstations/Z8PED12/HelpDesk_CPU/
it seems owning just 1
Dual-Core Intel Xeon E5502
as cheap as $5 60 on fleabay will allow flashing this mobo firmware, worst case.
Feb 06, 2018 | ASUS Z8PE-D12(ASMB4-IKVM) Dual LGA 1366...
I am usind Branded Dell Precision 690 Desktop Machine, i have already windows xp installed in it, but i want to install windows 2003 Server in it, but its creating a lots of issues to me to install server...
Before installing a Windoze server (no matter what flavour) you always need to verify the compatibility (drivers) with the machine's hardware... A Windoze XP driver will rarely work for a server environment... Micro$oft built all servers version to run in server machine type... further more you also need to verify softwar compatibility as well... as not all workstation software is compatible with server environments... and your machine advertises that it is a WORKSTATION NOT A SERVER...
Cheers!
Jul 28, 2011 | Dell Precision Workstation 690 - 750W...
Windows won't see all of my 4GB of RAM but BIOS does! Why?
Windows xp will usually only see 3.5 gbs of ram even in your motherboard can support more. WIndowns vista does recognize more RAM or i also believe windows xp 64bit recognizes more ram. Nothing wrong with ram or your computer its just your operating system.
Dec 18, 2008 | Dell PowerEdge 1600SC Server
DIsplay Problem with Intel Dual-Core Xeon® 5050, 3.0 Ghz Problem
Try using a different graphics card or make sure that you even have one installed in your computer. If no display is present on boot up, then your graphics card might be corrupt.
Oct 10, 2008 | Intel Dual-Core Xeon® 5050, 3.0 Ghz
Problem with DG31PR while loading windows 2003 server with 4gb ram
You MUST run a 64 BIT if you want to run anything more than 3 Gb of ram ( such as windows xp 64 BIT , Vista 64 BIT , or even winows 2008 server 64 BIT ) Windows 2003 does NOT support 64 BIT ....
Jul 29, 2008 | Intel DG31PR Motherboard
Purchase of workstaion/server for three diemnsion simulation
Hey sorry for the late reply
you dont need much surprisingly
1 AM2(X2) DUEL CORE DUEL PROCESSOR MAIN BOARD >> i suggest msi
2 AM2 AMD PROCESSORS abt 4.0 GHZ each
4 GB MEMORY
2 500 GB HARDDRIVE (SATA)
1 DVD BURNER
an alien case with a 650watt (or more) power supply
enjoy
Oct 26, 2007 | Computers & Internet
Open Questions:
See all EMC CLARiiON AX150 (AXS207500KIT) Network Storage Questions
EMC CLARiiON AX150 (AXS207500KIT) Network Storage Server Logo
408 people viewed this question
Top EMC Computers & Internet Experts
LP
Andrew Taylor
Andrew Taylor
Karl Luedemann
Are you an EMC Computer and Internet Expert? Answer questions, earn points and help others
