Question about HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Print Queue failure
The LaserJet 2600n printer is connected to a network and had been performing just fine for the last two years. Suddenly it stopped printing the other day. After I power cycled the printer, it prints one document and it quits priting again. It will print one document after I power cycle the printer and then quits. The panel says "Ready". I can ping the printer just fine. Any ideas??
  • 1 more comment
  • bluestars Sep 11, 2007
    Toner was fine. There was a IP conflict with the printer, I'm not sure what though.
    Changing the IP address of the printer fixed the problem.
  • sistersue May 20, 2008
    Our HP Color Laserjet 2600n printer quit printing. I can print the demo/conf page from the printer but cannot print a test page. I have tried everything from the manual but to no avail. It had printed a page and then it quit. Any suggestions to what I can check out. This is a shared printer and is connected via UBS cable. I have checked the cable and disconnected & reconnected. Also turned the printer on/off. I am at a lost.
  • Wired1 May 20, 2008
    Nice, That was right on. I added the 2600N to a server, and ever since, had to restart the print spooler after every print job. I went to the printer panel and entered a new ip address and everyone can print just fine now. Our servers give out DHCP addresses from 192.168.10.128 thru 254. So I just gave it an IP address lower than that. 192.168.10.27. No reconfiguring, or anything! Thanks!!!
  • 59 Answers
Blue stars, be careful to monitor that often. it seems lately that anti virus and firewall updates can tinker with those IP addy's. Took me several hours to figure it out!!
Posted on Oct 02, 2007
    Scholar:
  • 33 Answers
Sounds like low toner to me. If the printer is connected by USB or parallel cable to one computer, go to that one. Click start-programs-HewlettPackard-HPlaserjet utility. The utility should let you see how much of each toner color remains.
Posted on Sep 10, 2007
  • Anonymous Sep 11, 2007
    Good catch! Each device on your network must have a unique IP - printer, computers, router. The printer must have had the same IP as one of the other devices. I'm surprised that error message didn't show up in the beginning, even before you printed.
6ya staff
SOURCE:
Hp laserjet p1008 printer sharing print command stuck in queue
Which OS is this? If its on Windows 2003 or 2008 server then using the print management console as opposed to the start > printers option should resolve this issue. Print console can be found under admin tools in the start menu
Dec 07, 2010 | HP Color LaserJet 2600n Printer
Replaced black cartridge when machine indicated, but after two different cartridges ,it still shows replace black. What do I need to do?
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | HP Color LaserJet 2600n Printer
Network printer problem
try the usb cable if the computer can print print test that would be the network is wrong ip address that declare you on printer
Feb 04, 2010 | HP Color LaserJet 2600n Printer
Can't print to HP 2600n over network
The LaserJet 2600N has a built-in print server and can be connected to the local network (normal ethernet cable) directly. While printer sharing via Windows should work, I found it much more convenient to access it without the need of a hosting computer - you do not need to switch on the desktop PC for printing from the Laptop, for example, its also printing faster.
Jan 25, 2010 | HP Color LaserJet 2600n Printer
Strange Printer Issue - HP Laserjet 2600n
The last time I checked, you cannot set up a local printer using a TCP/IP port. A local printer is physically connected to a computer via a parallel, serial (very old), or USB cable. If the printer is connected to a switch, hub, or router via an Ethernet cable, it is by definition a network printer and the driver install must reflect this. I don't understand why it is able to print out the test page after the install. If you open up Control Panel -> Printers and double-click on the HP Laserjet 2600n in there, it will bring up the local spooler for the printer. You may have a bunch of print jobs queued up in there that it cannot currently send to the printer. You may want to clear the queue first (cancel all print jobs). Let me know if you have problems clearing the queue & I can give you instructions on how to do that one too.
Apr 23, 2009 | HP Color LaserJet 2600n Printer
Print jobs stuck in queue
First re-install the printer driver on that computer. If you can see the jobs in the queue, cancel all jobs and try again. Hope this helps.
Apr 20, 2009 | HP Color LaserJet 2600n Printer
Hp color laserjet 2600n ''black print down form its orignal place''
an allignment need to perform on printer with proper placement.
Nov 27, 2008 | HP Color LaserJet 2600n Printer
Lj2600n no output
i need HP colour laserjet 2600n software supporting to windows vista
May 07, 2008 | HP Color LaserJet 2600n Printer
Cant print in my network
I am having a similiar network problem, I setup the 2600n on my small-office network, plugging it into an 8 port switch along with a computer and IP camera....then connected the switch to the default router...this worked for a while as my router provided the printer an internal IP, but somehow the IP reset itself to an external IP,and print jobs I send now to the 2600n from my network will not print. I can't seem to access a configuration window to set a static IP address my router will recognize.
Feb 15, 2008 | HP Color LaserJet 2600n Printer
Print Problem in 2600n and Laserjet 1000
Just install 2600n manually and define as USB Virtual printer port!!!
Jan 24, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
251 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
