Question about Toshiba 42H82 42" Rear Projection HDTV-Ready Television
Converge semicoductor How do I remove and install a converge semi conductor?
    Scholar:
  • 173 Answers
With skill and experience. need solder wick or solder sucker(radio shack) screwdriver set, needle nose pliar, solder and solder iron 35 40 watts. desolder the IC all legs on bottom of pc board. pull the ic out with needle nose, install new ic ,u might have to bend and straighten the legs, dont force it. now solder all the legs carefully. GGGGGOOODDDD LUCK!
Posted on Aug 17, 2007
SOURCE:
How do I get the sim card out of my I phone 5?
Turn the phone COMPLETELY OFF.
- Put on your anti-static wrist band.
Remove the protective case ...
if you have one on your phone.
On the right side of your phone...
observe a narrow 5/8 inch slot with a small hole in it...
Using the appropriate release pin... (or small paper lip)
gently push into the hole and this will release your
SIM CARD...
Keep in mind THE tiniest STATIC spark can
(you might not even feel) utterly destroy the
most ROBUST of semi-conductors...
EVEN those big UGLY diodes in your cars alternator...
so always wear ESD (electro static discharge)
protection when handling any semi-conductors
YOU CARE ABOUT.
See below
Nov 17, 2016 | Cell Phones
What does esd strap stands for led tvs
Ground for Workbench
Be sure to place a conductive sheet or copper plate with proper grounding (1 Mohm) on the workbench or other surface, where the semi-conductors are to be placed. Because the static electricity charge on clothing will not escape through the body grounding band, be careful to avoid contacting semi-conductors with your clothing.
www.electro-medical.blogspot.com
Oct 13, 2015 | Televison & Video
Semi conductor electric cooler
These people have a similar fan motor.
http://www.appliancepartspros.com/search.aspx?model=dts%20181%20cr%20dr%20ww
some semi conductor fridges use mains operated computer-type case fans.
Aug 06, 2015 | Furniture
Numark ttx1 blowing fuses
Fuses blow when there's an overload. Most are caused by a semi-conductor that has shorted. If it was the bridge you can test with an ohm meter. Connection across it's leads will be just like touching the test probes together. That goes for any of the semi-conductor devices.
Mar 06, 2014 | Audio Players & Recorders
Panasonic PV-4664 VR wont't power on. Replaced 1.6A input fuse and fuse blows immendiately when power supply is both installed and removed from the unit. Appears the power supply has a problem.
Fuses blow like that when a semi-conductor has shorted and acting like a piece of wire. Transistors diodes etc will show up quick with a Ohm meter, has it will be just like you have touched the probes together!
May 08, 2011 | Panasonic PV-4664 VHS VCR
MY FUSE KEEPS BLOWING OUT
If the fuse keeps blowing it's because some part is acting like it is a piece of wire. It will probably be a semi-conductor in the power supply of the turntable, or the transformer. They often look burnt or damaged the semi-conductors in this state.
Nov 19, 2010 | Vestax PDX-2000MKII PRO Turntable
A small 2.5 amp fuse keeps blowing. It is located at the back of the unit just after the ac inlet
When a fuse blows suspect an overload in the power supply or power amp section.
For culprits in the power supply check the transformer, large capacitors, rectifier, voltage control semi-conductors, diodes.
In the amp section any semi-conductor on the heat-sink.
Semi-conductors - transistors and IC's are the biggest cause of fuse blowing. They become short-circuit acting like a piece of wire!
Because of this transistors and diodes are easy to spot with an Ohm Meter, as it will be like you have just touched the probes together.
Very often they have holes, or damage, or have burnt up with this kind of fault.
If it is a fault on the main amp section, check your speaker wiring as the + & - wires could have touched to cause it.
Apr 18, 2010 | Pioneer A509R Amplifier
Need semi-conductor parts for Proview TV/monitor
I need to know how to take off the base of my westinghouse flat screen. (42") That way I can hang it into the wall.
Oct 15, 2008 | Televison & Video
R52wh74 Convergence
If the convergence option is not on the menu anylonger. thats another issue all together. That is usually a fusible link and capacitor on the deflection board that will cause that to happen. The convergence ICs will also need replacing as the link and capacitor will most certainly take out the convergence ICs as well. You will need a service manual on this issue. Let me know and I will post a link where you can get one along with some free support to help you with it.
Mar 18, 2008 | RCA R52WM24 52" HDTV Projection Television
Blue convergence will not move left or right
look at the convergance board it will be the one on the left there re two stk semi-conductors tward the back of the board. most likly one of them are bad but sometimes the soldering can be faulty. look for signs of cold solder if so just resolder and should be good if not also look for burnt resistors. it will be obvious finding the stk 's can be done by using google and just type in the stk # finding the resistors you might try calling panasonic to find the part #by telling them the location of the burnt resistor. good luck. mind you that the soldering of the stk (semi-conductors) you will want to use a heat sink on each terminal you solder otherwise you take a chance of burning the conductor befor you ever get to use it, if you have no exp. soldering i wouldnt sugest trying it !!!!
Oct 17, 2007 | Panasonic PT-61HX40 61" Rear Projection...
Toshiba 42H82 42" Rear Projection HDTV-Ready Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
