Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Samsung Projection TV
Hi you all, Does anyone know the service code for the samsung projection TVs. if yes, please let me know how to enter the code. Thanks.
The remote with the set does not have the functions as described here
Posted on Nov 08, 2007
    Sergeant:
    Champion:
  • 375 Answers
To adjust the convergence it mute 1-8-3 remember to hold the enter key when you go to write then pess the focus key the set will go into a auto focus and stop when its done
Posted on Aug 18, 2007
SOURCE:
Samsung SP47W3HF Service Manual
I know a friend selling service manual for $5, maybe he has this model. Email him [email protected]
Feb 28, 2013 | Televison & Video
Samsung HDTV model HCL4715w1 has horizontal wavy lines in the middle of the screen. Is it worth Fixing? Any solutions to this problem?
Yes,tv screen have R,G,B colors lines mis alingnments,have colors shaded pictures or 3D pictures look aike?Tv have a problems known as convergence pictures problems.The tv convergence board it is dead.This convergence board must require replacement of 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to solved the tv convergence pictures problems.U have some mechanical skills like take things aparts and putting it back together again?Yes,try website like Tvrepairworld.com to buy a whole refurbish tv convergence board for the replacement.The DLP tvs brands names Samsung and Akai used the same tv convergence board.Or tries those tvs shops will cost u like $300-$350 for parts and labors.
Jun 28, 2011 | Samsung HCL4715W 47" Rear Projection...
I have a projection tv its 3-4 years old and in one corner of the tv i have small white dots like stars, it started with just a few and it is now multipling and spreading. What could be wrong with the tv?
Very expensive repair must be replacement of the light projection engine block to sloved this problems.This problems are happening to many tvs brand 50-70 up DLP projection tvs like Samsung,Toshiba,Misubishi,Sony because they all put in the same problems IC design on their projection tvs on their light projection engine block.Talk to Samsung,might get some help with the repair.
Feb 16, 2011 | Samsung HC-P4752W 47" Rear Projection...
I have a toshiba tp55c80 changed both stks still the same....
You are going to need service code for entering into Techician realining of convergence CK all small ohm resistors near ICs 1.5 2.7 3.9 ect.. I cannot find Service code, list Need Service code to enter Convergence Pattern.Will try to find my List of service code for all TVs and list them but untill then Try Listing Looking for service Code for Toshiba.
Aug 14, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Green out of alignment on samsung rear projection tv
LOOK for 3 parts that start with STK (BLACK THINGS THE SIZE OF A MATCHBOOK) then replace all 3 (ebay) also look for some green coils that may be burned. If you SEE THE STK's then your in luck, as 95% of them are bad.. Please rate!
Mar 30, 2009 | Samsung HCL4715W 47" Rear Projection...
Samsung HLP4663W Black Solarization
The speed of the color wheel needs to adjusted or the CCA values. Both are found in the service menu . If you paid a company to fix the TV, call them and tell them that they forgot to perform these alignments. If you did the repair yourself, you'll have to call around for a price to have a Samsung service center perform these adjustments. I don't recommend consumers access the service menus of modern TVs because one wrong button push and you may cause irrepairable changes to the TV's proper operation.
michtech
Feb 18, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Service code needed to complete convergence adjustments
I have the service convergence code: mute-1-8-3 (make sure your tv is on and set to antenna. if it doesn't work press S. Mode and make sure is says standard then re-enter code.
So, I have the code but I need the convergence chips. Where did you get the convergence chips?
Jan 26, 2009 | Samsung HCM653W 65" Rear Projection...
Rear Projection Samsung w/ convergence out
I believe it is mute-1-8-3 to enter the service mode, HOWEVER, I have also read that until the convergence problem is repaired, i.e. - depending on the configuration, either 2 individual IC's located on the lower board with 'playing card' size heat sinks or a simple replacmenet convergence board, adjusting the convergence through the service mode is comparable to "ripping the transmission out of your car to fix a flat tire". I myself have not gone into the service mode since I am still waiting for the replacement IC's - I get to do a component level repair.
May 05, 2008 | Samsung PCL545R 54" Rear Projection...
Samsung sp43w6hpx/xeu
Yes you must go to menu and set the convergenge. It is easy. If it doesnt tune in or set to be ok you must get somebody to set convertions manualy thru service menu.
Hope it help
Aug 10, 2007 | Samsung HCN436W 43" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
77 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
