SOURCE: 2001 Hyundai Elantra - All four windows inoperable
1. Remove the switch from the door trim panel. 2. Check for continuity between the terminals. If continuity is not as specified in the table, replace the power window switch. POWER WINDOW MAIN SWITCH WINDOW LOCK SWITCH
SOURCE: Driver side door lock stopped working
sounds like the lock motor is locked up or probably broken connectors yo have to open the door panel to check this out.
SOURCE: 2003 Dodge Ram 2500- window master switch
Alot of times these switches get water from the rain coming in intoo them causing the contacts to short or not make contact at all, unfortunately they are not servicable but you may want to try spraying some electrical cleaner into the switch working the button at the same time this may help
