After about 20 minutes my toshiba satellite p205 notebook shuts down. It is not the battery because it still does this when plugged in. when it is on it works fine.
Your laptop is probably overheating due to an obstructed airflow path or a failed fan. Get some canned air and thoroughly blow out any dust and debris that may be blocking airflow. Sometimes the heatsink cooling fins get matted over with fibers and a lint ball will form in the fan-cage obstructing the fan rotation. If this happens it is often necessary to remove it with tweezers which may require some dissassembly of the notebook.
Was this helpful?
Yes
No
Popular Solutions for Toshiba Satellite P205-S6287
Need ALL Drivers to a ADVENT 5544 NO Laptop.Has Windows XP Home installed.Well,,nothing else...
(More)
Need ALL Drivers to a ADVENT 5544 NO Laptop.Has Windows XP Home installed.Well,,nothing else works,no usb sockets,soundcard etc.
lost all my sony files off my laptop so got 3 recovery discs off sony.Download ok but on recovery...
(More)
lost all my sony files off my laptop so got 3 recovery discs off sony.Download ok but on recovery stop short with the error 63,also theres a clicking noise only at the end.
 Sunday, April 13, 2009 To whom it may of concern, Herewith I have to bring forward my...
(More)
Sunday, April 13, 2009 To whom it may of concern, Herewith I have to bring forward my disappointment that after a day of work, I could not close my notebook Toshiba Satellite P20 (Serial number: 74353716K; Part number: PSP26L-0PPJ9; Made in China; with Windows XP Home Edition), because of an enormous cracking noise. Screws and other little parts were jumping around. The hinges at the backside of the casing were totally deformed; this may be caused by the outgoing flow of the generated heat. I therefore was obliged to left my notebook open and had to bring it to the shop were I have bought it. They brought it to a center of repair in Jakarta, the costs of repair were quite high, i.e., IDR 4.75 million and it took more than two months to have the job done and with no warranty! The main issue is that there is something seriously wrong with the management of the generated heat. Here is a feature where one has obviously to deal with a wrong design of this P20 model. This is very sad, since this P20 is my workhorse and I am very happy with its specifications. With this letter I hope to contribute to an improved design of the notebook Toshiba Satellite P20. Sincerely yours, Adrian Venema Jl. Cisatu I, no.1 (Ciumbuleuit) 40142 Bandung Indonesia e-mail: adrinnuha@bdg.centrin.net.id
comier957, Thank you for your attempt to help me with my problem. You offered a solution and asked...
(More)
comier957, Thank you for your attempt to help me with my problem. You offered a solution and asked me to let you know. I attempted to let you know what I had done but do not know if you received my reply. Thought I knew how to send it but it did not post under my original question. . Anyway, I had one SATA burner in port 1 and one SATA burner in port 3. Since I posted the question I traded one SATA burner for a Samsung IDE burner giving me 1 SATA Burner and 2 IDE Burners. Each of them seems to work as it should. Sorry I "jumped the gun" and made the trade. You most likely could have solved my issue. Thanks
