Question about Kenwood Excelon KVT-915DVD Car DVD Player
No sub Screen blanks out when watching a video. Normally, I would shut the unit down and cut it back on to reset the unit. It usually works but now you can vaguely see the picture. But during really hot days the picture display is perfect. What can I do to fix the problem. Thanks David
Let it cool down,
Posted on Sep 24, 2007
SOURCE:
HP G62 black screen on start up
If it has no "ghost image" on the monitor, nothing, it could be a connection issue, a ribbon cable on the rear of the monitor, the inverter, a tiny switch the operates the on/off of the backlighting when the lid is opened or closed, sometimes located near the lid hinges. Have you tried a External Monitor? Take a look at this video, it may help troubleshoot the issue: http://www.youtube.com/watch?v=2Yi6GNFcP3w
Feb 26, 2013 | HEWLETT-PACKARD HP G62 Notebook
Hi i have two 12inch l5 with dual4voice coil one is not working i think because the speaker works till turned up to like 10 then repeat cuts the amp off unless u keep it down then plays fine so i think...
OK, are you using a 2 channel amp? If so, the problem could be in your amp. If you are saying that when you turn it up real loud the amp shuts off, then comes back on after you turn it down. Your amp is going into protection. Most amps are not equiped with thermal and voltage protection. This means if the amp is too hot, it will shut down before it melts the motherboard. Also, if it detects fluctuations in voltage, it will shut down. Things to think about. How many watts RMS is the amp supposed to do and at what ohms load it is stable at. How to I have my subs wired (series, parallel), and what ohm load am I asking from the amplifer.
Now, each dual voice coil sub should have two sets of + and -. Each one of those + and - sets provides the power for a single voice coil. So, by unhooking one side, you not reduce your sub to operating on a single voice coil. Not a good idea, since it will wear down that coil and it will fail.
If you are saying that you "cut" wires on the sub, like between the + and - connectors and the spyder, you are ruining the sub. Those wires can be soldered, but usually don't perform like they were designed and usually fail shortly after the repair. A white dot on one of those connectors usually represents the positive side of the connection.
You will probably end up investing in another sub. Also, you need to think about your amplifier situation, before you blow another sub. Hope this helps
Aug 24, 2011 | Car Audio & Video
The touch screen does not reacted when touched. The battery is fully charged and the software has been updated.
These units have a common problem with touchscreen failures. Please see this link for more info and how to have it repaired:
http://www.sharc.net/gps_LCD_repair.htm
Jun 11, 2010 | Garmin Nuvi 660 GPS Receiver
When I power up laptop screen is blank
You may have a burned video adapter.
A trouble shoting setp you can try is attatching an external display and seeing if that works.
Also try the function F5 key combo. I think that is the ASUS mapping to switch display output.
Aug 04, 2009 | ASUS Eee PC 900 Notebook
46 inch Sony flat panel lcd has vertical red and green lines down right side of screen and you can be watching tv and picture will go right out and leave grayish blank screen until restart. Black...
If the screen works for a short while and then completely fails once the TV warms up you have a problem with the main unit video board or the LCD control logic board. Most often if the picture cuts out but audio continues to work the logic board is over heating and should be replaced. However if the picture cuts out and audio shuts off as well then its your video input board.
Apr 28, 2009 | Sony Televison & Video
Pioneer avh-p6500
press the reset buton to make the screen problem rectify itself
you need a hideaway unit for adding subs
Aug 23, 2008 | Pioneer AVH-P6500DVD Car DVD Player
T-Touch just stops and goes blank, then will restart without notice
the problem of your watch is circuit block,or lcd liquid crystal digit,try to replace the circuit or lcd,
Aug 23, 2008 | Tissot T-Touch T33759851
Screen goes blank
Maybe the setting of your video display was change to higher setting, and your screen cannot handle the said setting.
When a "safe mode" message appears during opeing, select that options, then at the desktop right click your mouse, chose properties, then setting, then change the screen resolution to lower range.
Dec 05, 2007 | GPS
Pinoeer DVD-366
Hi there, just got that progresive problem gone :D
- Startup ur DVD (ON)
- Wait until Loading - No Disc (status on DVD display)
- In here, ur screen still blank (black screen)
And here's how:
- Press "Home Menu" button
on ur DVD (it should be on the down left of the circle button)
-- Watch out, the screen still in blank, just feel it right ok?
- Down 2x -- Initial Setting
- Menu / Ok (the circle button)
- Down -- Video Out
- Menu / Ok
- Down -- Component Out
- Menu / Ok
- Down -- It will choose Interlace, it will saved the day :-)
- Menu / Ok
That's it.. Cheers mate ^^
Give me a mail if u still have the problem, coz I Know how it sucks.
[email protected]
Dec 02, 2007 | Pioneer DV-366K DVD Player
Kenwood Excelon KVT-915DVD Car DVD Player Logo
37 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
