Question about RCA TruFlat 27F520T 27" TV
Truflat 27 inch rca
2 inches of the top of the screen is white lines is there a solution the i can do?no talent just dont want a repair bill
  • 67 Answers
Vertical capacitors beside of vertical ic no other problem the capacitors only
Posted on Sep 17, 2007
White horizontal lines on top of screen
Replace all the electrolytic capacitors in the vertical output section circuit. There will be 5 or 6 of them. Replace the at one time. The fault you see is technically called " vertical retrace lies".
Apr 28, 2012 | RCA 27F524T 27 inch TV
On my RCA truflat tv there are solid white horizontal lines going across the top 5 inches of the screen? Do i need to get it repaired or is it a simple problem?
Your TVs vertical output section has the trouble. Electrolytic capacitors in that section, 8 numbers the most, should be replaced with new capacitors. Iit won't cost more. OK.
Jun 12, 2011 | RCA TruFlat 27F520T 27" TV
Visual transparent lines at top of picture
You have a vertical output circuit problem. This was common for Philips' sets. Have a repair shop check it out. Should not be too expensive to repair.
Oct 15, 2009 | Philips 27PT6441 27" TV
RCA 27 in has white horizontal line going through the middle
this symptons is caused by a breakdown in the vertical deflection circuit. hence, the trouble may be in the vertical oscillator, amplifier or output circuit. in most modern tv the vertical ic is usually composed of these said circuit inside. the ic have many pins, standing on a heat sink and smaller in size. try to check also the capacitors surrounding it. sometimes leaky capacitor may cause this problem. good luck!
Aug 16, 2009 | RCA TruFlat 27F520T 27" TV
RCA tru flat 27 tv problem
the capacitor of vertical section is problem of your tv,so replace the capacitor value 100/50volts in or else all capacitors in vertical section.
Oct 14, 2008 | RCA TruFlat 27F520T 27" TV
RCA TruFlat Tv problem
Jun 09, 2008 | RCA TruFlat 27F520T 27" TV
White lines accross top of screen on our 27 inch Toshiba,
lcd or plasma.
are the lines solid or blurred. do they have sharp edges.
You may have a memory problem with the display which can only be repaired by factory trained technicians, or a brave soul willing to find parts on ebay.
May 02, 2008 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
13 inch rca true flat tv
if it is a straight thin line from left to right you have a vertical problem time to call service tech
Nov 29, 2007 | RCA TruFlat 27F520T 27" TV
Top four inches of screen running horizontal is distorted.
The problem is most likely in the vertical circuit, possibly the vertical IC itself or one of the feeder caps in that circuit. Could be possible poor solder connections on the IC also. Is the problem intermittent? There are a number of common problems with this unit effecting the following parts: Dp027 (27v Zener) P/N 244835 Tp022 (Bc648) P/N 198743 Tp025 (Bc558) Ip001 P/N 257786 Ip050 Ic Voltage Regulator , Zener Diode With 3 Legs Looks Like Diode. Ip030 263567 Dp057 232662 Tp052 198743 Tp020 (2sk2842) P/N 263692 Tp023 (2sc8550) P/N 257827 Dp025 244870 This is an ITC008 chassis built in mexico and the problem you're describing should be an inexpensive repair - but my downside opinion is that with this particular unit you could expect the next problem in about one to two years. Being a certified technician there are few TV's that I would tell a customer to walk away from if they were considering a purchase - but this is one of them. I'm sorry for such a negative review, please don't take it out on my rating for this solution. But if you have it repaired take it in yourself and save a few bucks - and ask the shop to save all the old parts for you. Good Luck Bill
Jun 12, 2007 | RCA 27F530T 27" TV
RCA TruFlat  27F520T 27" TV Logo
243 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
