Question about Plantronics 510 Voyager Headset - PLN-510 Headset
Plantronic 510 want to open cover
Seems that my volume down switch is not working - feels loose/not connecting. I want to open the cover to see if I can fix without sending it away to service. There seems to be a slot near the charger plug...
  • mmiille Nov 04, 2007
    I am having the same problem Plantronics has been no help.
  • 5 Answers
Why bother.  Send in with copy of receipt.  One Year Warranty covers most problems (not physical misuse or abuse though)  Do not open unit.  Will invalidate warranty.
Posted on Mar 12, 2008
6ya staff
SOURCE:
Volume down button doesn't work
hi, make sure the face pins are clean; try resetting the unit; check to see if the feel of the down switch is the same as the up switch....if not then your down switch is faulty and needs to be replaced. confirm the volume down operation by using the remote control (if available), if it works then your problem lies with the switch or a broken connection between the switch pins and the face control circuit. cheers.
Jun 21, 2012 | Blaupunkt RPD-545 CD Player
Just purchased the quantico phone trying to pair it with my plantronic 510 headset but need help
Press and hold both the Speak Volume Adjust Buttons on the base unit until
the indicator in the Call Control Button starts to flash.
Press and hold the headset Listen Volume Adjust + Button and headset Call
Control Button until the Status Indicator flashes red and blue.
Pairing completion is indicated when the Call Control Button indicator
illuminates solidly, and the Status Indicator flashes
Here is link to manual if you need it:
http://www.plantronics.com/us/media/media-resources/literature/user_guides/voyager510_ug_gb.pdf?WT.dl=20
Good luck
Apr 16, 2011 | Plantronics 510 Voyager Headset - PLN-510...
2008 te 510 on attempted start up using electric start it just turns over and over does not fire at all. Seems like there is no fuel however the tank is full. Any ideas would be helpful.
its the on/off switch next to the throtle,the same fault hapens on ktms exacly same switch,feels like switch is working but it aint
Jul 04, 2010 | 2008 Husqvarna TE 510
Plantronic 510 not charging properly
no it has a smart charge system which does not allow for that to happen.
Thanks,
Nate
Sep 23, 2008 | Plantronics 510 Voyager Headset - PLN-510...
The blue light doesn't turn off
Hey, I have managed to turn off blinking in My Plantronics 665 by
first: Turning off headset,
then pressing volume up and turning it on.
It will blink to show that it is on, , then blink one more time to show, that it is connecting to phone, and thats it, : no more blinks,
So You don't look like UFO :-)
Cheers from PL.!
XRafX
Aug 12, 2008 | Plantronics Explorer 330 Headset
Plantronic 510s
The Voyager 510 is not a good fit for that phone. I would prefer the cs55 or awh55.
The headset will work with the phone, but will not alert you when there is a call.
Jul 03, 2008 | Avaya 5400 Series 5410 Phone
Bluetooth issue
On the top of the ear piece, there are two buttons, one is the volume up and down, the other is on/off. Press and hold until you see a blue light on the piece that is the mic.
Nov 13, 2007 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics 510 Voyager Headset - PLN-510 Headset Logo
105 people viewed this question
Top Plantronics Radio Communications Experts
Anthony Ward
Anthony Ward
gggg
edward80
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
