Hey i disconnected the battery from ym car and i hooked it back up and the car wont turn over, wont crank wont click, nothing. lights come on inside and out. i thought it was the alarm but i cant find a reset switch or anything. ive tried cranking while pressing every button (sepperatly). im in a real jam here
I had the same problem because I store my car in the garage in the winter. I found that replacing the positive/negative cables with new ones and also if you still have your spare key, try putting one key in the ignition and turn to acc before turning it over click your alarm button on your spare set of keys and the alarm should reset itself and the car should start. i hope this helps you, i just finished changing my spark plug wires because I had a code P302 which made my 2nd cylinder misfire, so if your tiburon is around 180,000 km then you should change it too, I recommend Bosch they are the best.
take care
Sven
I canged the battery and now the horn blars intermittently, the car will not turn over lights work but no engine response...help!!
