Question about Samsung LN-S4092D 40 in. LCD HDTV
No picture I just had HD installed from comcast. it was working fine for the first day, but now I have no picture. I still have sound for all the channel, but I have a blank gray screen instead of a picture. I must've pushed some button on the tv remote? anyone know how i might be able to fix this?
  • mitzo101 Mar 15, 2009
    Is this fixable by myself? I hear sound, but no picture, so I can't see the screen to change the resolution or the source. Any ideas?
I am having the same problem. samsung says that it's a firmware update needed. they say that tv's made before June of 07 will need (require) this upgrade. i've not heard of a tv needing such but i've never had an lcd tv before. i'll try to post back once we get the firmware in the mail (they're sending us a jump drive) and install it. see if the problem gets resolved. have you had any luck or updates on the status of your issue?
Posted on Jan 27, 2008
IF THERE IS NO PICTURE YOUR TV HAS BEEN SET TO A DIFFERENT RESOLUTION THAN WHAT IS COMING IN
Posted on Jan 10, 2008
SOURCE:
My Comcast Proscan HD TV has a small screen on non HD channels.
I have 2 pro scans Comcast hd. On Comcast remote small button ( for me Its small circular button bottom right) HD ZOOM. (enter above it)
Aug 30, 2012 | Televison & Video
I can adjust sound on tv but not with remote
your remote should be opened and service it, a +button -button are not toggling making contacts, or one is holding permanently inside a remote thanks.
Mar 26, 2009 | Televison & Video
Am i getting hdtv with just cable feed?
Depending on your cable provider, some of the HD channels may be present. If so, these are ususally located in the upper channel numbers. It sounds like you are receiving some of the HD lineup. A cable box will probably allow you to view more HD channels including the premium HD channels if you subscribe to them. You should not be noticing a delay with the HD channels only. If this is what you are experiencing without a cable box, then it would be an issue with the HD tuner built into your TV set. LG customer service can let you know if there are any software updates available for yourmodel that can resolve this. Additionally, if you are getting your sound from an Home Theater system then you will notice an echo if using the TV's built in speakers at the same time. This is sometimes mistaken as an audio delay. If you are using a home theater system, be sure to disable the speakers that are built into your system.
Jan 04, 2009 | LG 37LG30 37 in. LCD HDTV
No Picture
Do your on screen display work when you push menu?
Jun 29, 2008 | Philips 51PW9363 51" Rear Projection...
No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 26, 2008 | Insignia LCDTV26 26 in. Television
No Non-Hd sound
Jun 19, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Samsung LN-S4092D 40 in. LCD HDTV Logo
198 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
