Question about Candy AQ130 Front Load Washer
Programme dial hello, model AQ 130/1T80 candy when started it does not move on to next program found problem no power going to motor at back of dial ,took dial apart to check connections all good , power is going to circuit board at dial but not to motor ,replaced springs from circuit to motor with copper wire still did not work , should i buy a new program dial and motor Thanks , whitfield.
  • Diallad Mar 22, 2008
    Hello.I am changing the program dial on mums candy c1040 washer as all lettering has worn away.Got new dial but I didnt realise that I have to get ito the top of machine to change it.Is it an easy job ?I havent taken top off yet. PLease help.Thank-you.
    Novelist:
    Champion:
  • 244 Answers
That is your only solution but u might find u can buy a second hand machine that works for u to get parts off this will proberly be cheaper than buying a timer thats what id do u get more for your money m8
Posted on Aug 14, 2007
SOURCE:
Indesit WM12X the wash program starts then freezes (The dial doesn't turn)
Sounds like the dial timer is defective, I am not affiliated with this site, https://www.repairclinic.com/Video
Apr 25, 2017 | LG WM Washing Machines
DISHWASHER GETS STUCK ON THE 1ST RINSE CYCLE
see the diagram attached.
1) Test the switch door,it is defective, the starting relais turn off, and consequenc the motor off.
2) TIMER: TEST FOR DEFECTIVE, clean contacts, repair wires loose, burn or broken.
God bless you
May 09, 2012 | Candy Dishwashers
1)My Candy DFI 50 is not washing properly, it leaves residue on the pots. 2)The programme controller on my DFI 50 seems to be sticking. Sometimes the dial doesn't move at all or takes 'hours' to run a...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Aug 09, 2010 | Candy DFI Plan Built-In Dishwasher
Problem with candy dishwasher model CSF 456M.
hi it may need a new inlet valve,can you hear a humming sound when its due to fill.or is it doing nothing.if its not humming change the valve,also these dishwashers are well known for overheating and sticking on cycle.
Jun 01, 2010 | Dishwashers
Candy cs455m programe stops at about 3oclock on the dial
Yes heatr should be submerged in the water. Not expose to free air.Check the water level float switch or the pressure switch.
The replace timer should be identical in design. If there is a mismatch it will not function as designed.
If it is elctronic micro controller type the same part no and soft ware version should be used.
May 25, 2010 | Candy 17 in. CS455 Built-in Dishwasher
I have a candy AQ 1200, it fills with water then drum turns and s
sounds like m/c is waiting to heat up water but heating element is not working or timer switch not going on to next cycle.
Aug 21, 2009 | Candy Washing Machines
Washer won't spin/drain water - no noise, just won't work
might help found my problem was in the motor thought it was in the controls but it came back to motor problems . changed control dial no luck .would think if its a fix yourself try control first. its cheeper than the compressor hope this helps
May 22, 2009 | Kenmore Washing Machines
Candy AQ130 Front Load Washer Logo
169 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Kolbrun...
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
