Try *#05 if that doesn't work then you need to call your phone company. They have a master unlock code that you can use to fix your problem, Sorry your having so much trouble with it, hope I helped you!
hey friends try this ...samsung monte file manager password reset...... 1st ype this no on dialing screen....*#5239870*#...it flashes and show you the admin settings..select pre configuration..after selecting it wilask to enter the code ..enter dis code *#27236*#..select confirm..after dis select 1st option..not kcr....and your phne wil restart and it becomes new... free of passwords.....note: befor doing dis(remove your sim card and mmc)
Don't worry you can unlock samsung a177 password using PUK code, enter any password until your phone request your puk code then insert your puk code. But i doubt this since your sim card and your phone already lost for a couple month maybe your sim already blocked too so try to use samsung network unlock code or reflash your phone to nearest local mobile phone repair shop.
If you put in your information on an untrustworthy site, your email may have been hacked. You can try clicking "forgot your password?" or "Forgot Password" and request to enter a new one. Also, make sure Caps Lock is off when you enter it.
Sir, you have set one of the above passwords. If you have forgot one then enter the second as an alternative. I assume that you have given 1 password and forgot it, thus you remember the second. If you have never changed the second code ( the on you have not forgotten ), it is surely is at default. You can easily obtain the second code from the manual.
Puk code is needed when you have entered the pin code wrong 3 times.
If you have a phone lock code on it and you can't remember to code try the defaults 0000 1234 12345 00000 etc. if you can't unlock it contact your dealer with proof or pruchase or contact a samsung service center, you can get those details from www.samsung.com you will most likely have to send the phone to be unlocked.
you can try entering these two codes without a sim card in the phone. write them where you would write 911 phone should restart. then insert the sim card and try turning the phone on.
*2767*3855# = Full Reset
*2767*2878# = Custom Reset
If these don't help then contact samsung for unlock service you will most likely have to send the phone to a service center.
If you can enter *2767*3855# without the simcard then that's the way to unlock and reset it but it will delete all information stored on the phone. Unfortunately, if you won't be able to enter the strings of command completely, then there's no other way to unlock it but to send the phone for repair to Samsung service center.
