Question about Dual XDMR-7700 CD Player
Bad face plate!
My unit goes crazy! Turns on and off! Switches between CD, Radio, and Aux... Changes Radio stations, Makes CD fast forward, rewind and skip... Only thing that works correctly on the head unit is the volume control... It usually takes a few trys to get the buttons to do what their suppose to do. But its impossible to use the player because it does random stuff.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
It may be the flexible connector link connecting to the drop down faceplate.
Posted on Aug 28, 2007
SOURCE:
Turns on but will not play. Makes a loud sound like motor running.
The unit needs service work- something may be stuck.
How can anyone give you any info without a rand or model number?
Apr 17, 2015 | Audio Players & Recorders
Unit has power and lights up. None of the buttons work and cd wont eject. The CD eject button turns the unit off but won't eject the CD. Cannot change the functions. Have reset the unit and checked th
Remove the face plate and clean the contacts on both the head and the radio. It sounds like a bad connection, The base and head use serial data to talk to each other(control).If one of these connections are bad the unit will not work properly.
Oct 06, 2014 | Sony MEX-BT2900 Bluetooth Car Stereo with...
I have a eur7711150 remote for a panasonic radio that was my dads.. i cant figure out how to change channels on the radio.. hate to sound so stupid but there doesnt seem to be a tuner or a seek button
The EUR7711150 remote works for several different Panasonic CD stereo systems. To switch between AM and FM, press the Tuner/Band button. (If you were in another mode, you'll need to press the Tuner/Band button once to get to the Tuner mode and then toggle if needed.) Then if you press Play Mode (above Repeat to the left of the number keys), you can toggle between Preset and Manual. In Preset, the rewind and fast forward buttons select between your preset stations. Alternatively, you can set the presets to numerical values and touch the appropriate number button. (Touch the >=10 button first to access Memories 10-15.) If you are on Manual, the rewind and fast forward buttons will let you move up and down between the frequencies. Pressing and holding Rewind or Fast Forward for a moment will let the radio scan to the next frequency in that direction with a signal.
The CD button enables the CD or MP3 disc player mode. AUX and Tape are for external audio devices and cassette tape mode, respectively.
These comments are based on using the remote with the Panasonic SA-PM19. Please add a comment with the specific model of your Panasonic radio if you need additional assistance.
I hope this helps.
May 05, 2013 | Televison & Video
Radio stations wont store once key is taken out
if the unit only looses radio station presets then there is a defect with the unit. if the unit looses all its memory, (clock, stations, settings) then there is an issues with your aux power. basically you have the main power connect properly so it turns on the unit while the cars is on but the aux power keeps those settings.
Mar 08, 2011 | Virtual Reality VRCD500-SDU CD Player
Hi! I got Sansui DA-T550 reciever which is a bundle with amplifier, FM, tape deck and separately connected automatic grammaphone. THe problem is with tape deck. When the whole unit is turned ON, the...
Hi Taff,
I had this problem too. In the end I opened up the box ( a real nightmare) found a "computer ribbon" style wire between the tape bits and the amp bits and disconnected it. I can't use the tape anymore, but it doesn't make any noise either. Like you (in your solution) I hate the way it switches to the radio when a record finishes. I have a CD player connected to the aux play jacks - when the aux button is pushed in, the radio is disconnected and when the CD finishes, you get silence not radio.
Dec 08, 2010 | Audio Players & Recorders
The dictaphone wont rewind or fast forward and makes a bleeping noise
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
Dec 07, 2010 | Dictaphone 1740 Desktop Cassette...
Hooking sat to car stereo
that plug at the back is not for sat radio. It is for use with steering wheel controls. You have the blue plug at rear of stereo and that is the plug for sat radio. Ericson electronics is contracted to build the sat compatible units that wire into this radio through the blue. plug. if you are using 3.5 plug audio control from a portable sat receiver, the you will need to buy an aux input cable for your stereo..
Sep 25, 2009 | Pioneer DEH-P3700MP CD/MP3/WMA/WAV...
When we Fast Forward or Rewind the screen turns blue
try to not fast foward and see what happens
Apr 15, 2008 | Televison & Video
Clarion marine radio
did they all do the same thing?
Apr 10, 2008 | Car Audio & Video
Dual XDMR-7700 CD Player Logo
125 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
