The bluetooth is connected the caller can hear me but I can't hear the caller
SOURCE: How to make Bluetooth discoverable
I have this radio also, and it took me a minute to get it to work. If I remember correctly, there is a button on the top left of the face that says BT. Press and hold this for about 5 seconds, and it should activate the internal Bluetooth. Not sure if I am right or remember all the steps, so here is the manual as well:
http://www.docs.sony.com/release/MEXBT2500_EN_ES_FR.pdf
SOURCE: my mex-bt5700u only plays sound while I have the
What make/model of car? I'm pretty sure that it is because your car has a factory amp that is powered by the factory radio. You will probably need a signal inverter and wiring harness or to splice into the wire; powering the factory amp and sending the signal to your radio.
SOURCE: Unit is Sony Xplod MEX-BT2800, connects just fine,
same problem bluetooth connects to two different phones but no audio from speakers every other function works fine just no audio from the bluetooth
