SOURCE: toyota rav 4
I can get you a diagram on monday but it goes from the alternator to the power steering pump then around the tensioner pulley then around the crank pulley then to the a/c compressor then pull on the tensioner to give you some slack and slip it on the waterpump.I hope that helps.Let me know if you still need the diagram
SOURCE: 2003 Toyota Echo radio/clock not working.
Disconnect your negative battery cable for about 10min. After you re-connect, the stereo should reset itself and start functioning. Best of luck!
Greg
SOURCE: 2006 toyota rav 4 fog light bulb replacement
fIRST YOU SEE A RUBBER GASKET SURROUNDING THE HEADLIGHT PLUG IN THE BACK OF THE HEADLIGHT ASSEMBLY. pULL OFF THE GASKET AND LET IT HANG ON THE SURROUN DING HEADLIGHT WIRES. tHEN PULL OFF THE HEADLIGHT WIRE HARNESS BY GRABBING THE SOCKET (NOT THE WIRES). AROUND THE BULB IS A THIN SILVER HOLDING SPRING THAT LOOSENS BY SQUEEZING THE ENDS TOGETHER AND ROTATING IT. iT WILL LOOSEN AROUND THE HEADLIGHT. WHEN THIS HAPPENS THE HEADLIGHT WILL "FLOP" AROUND AND PULL IT OUT, REMEMBERING TO SEE HOW THE THREE CONNECTORS ARE LOCATED (I.E - IS ONE CONNECTOR AT 12 O CLOCK POSITION AND THE OTHER TWO ARE AT 9 AND 3 OR ARE THEY AT 3,6 AND 9, ETC.). rE-ASSEMBLY IS THE OPPOSITIE. tHE TRICK IS TO GET THE THIN SPRING WIRE BACK IN PLACE. YOU HAVE TO SQUEEZE THE SPRING AND RE-POSITION IT SO IT KEEPS THE BULB SECURLY IN PLACE
Having just changed the bulb, I would advise taking the whole headlight assembly out first. It is near impossible to feel or imagine how to change the bulb without seeing it. First, use a phillips screwdriver to take the single screw holding the strip off just below the headlight assembly. By doing so, you will now see the other two bottom bolts holding the headlight in. Take all four bolts out then disconnect the bulb from behind. Then proceed as above.
SOURCE: MY 1994 fuse for
Another fuse block is located in the drivers side knee bolster behind a coin box—1994-96 models
On the back of the coin box on some models is a fuse listing
SOURCE: location of fuse box in Rav 4 1997
Yes there is also a fuse box under the hood. The schematic for fuses should be in the fuse box cover.
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
2006 Ford Expedition radio not powering ON?
http://technoanswers.blogspot.com/2012/01/2006-ford-expedition-radio-not-powering.html
How to reset Radio code after car battery is
died?
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
These details will help.
Thanks.
