Question about Pentax MX 35mm SLR Camera
Pentax MX Mirror Stuck In Up Position
The mirror on my Pentax MX is stuck in the up position, so that when I look though the viewfinder I see nothing. I have changed batteries, and it flips down correctly about 1/30 of the time after a shot. Is this a electrical connection problem, and what can I do to fix it? How much would a fix for this cost at a camera repair shop?
  • hatan1 Aug 18, 2008
    The exact same problem plagues my MX every few years. I've spent enough on repairs and would like to know how to troubleshoot this myself. the previous comment said it's easy to do, but didn't explain how.
    Thank you.
    ajd
    Problem Solver:
  • 15 Answers
This is a result of the linkage from the shutter release button being out of adjustment. It is a mechanical fault that can be repaired very easily.
Posted on Aug 29, 2007
Why is my camera taking picture in reverse through the viewfinder?
This sounds like a mechanical problem inside the camera. If it has a flip-up mirror behind the lens, for example, the mirror may be stuck in the up position. Have it serviced by a qualified technician.
Nov 06, 2014 | Olympus Cameras
Viewfinder blurry Pentax K100
The image is directed by the lens to a mirror then to a prism then to the viewfinder. The mirror flips up when you take a picture so the image can reach the film behind it. If the lens is ok it is possible that the mirror is very dirty or not returning completely to the proper position after a picture is taken. If the mirror is dirty you should have it professionally cleaned because it is a very light weight metal mirror and VERY EASILY SCRATCHED. If you have another lens then mount it and see if it is also blurry and cannot be focused.
A few cameras like certain Olympus models have a mirror lock up option which you use after focusing the image while the camera is on a tripod. This gets rid of the slight vibration caused by the mirror swinging up out of the way while taking. a picture.
If all else fails you might consider taking it to a good camera shop if you can find one.
Digital cameras are getting better and better but there are still things film cameras can do that most digitals cannot. Long exposures in "Bulb" mode and multiple exposures are among these. Also each brand of film has it's own Artistic color expression such as Afgachrome vs. Kodachrome.
Jul 16, 2013 | Pentax K1000 35mm SLR Camera
The viewfinder screen is completely black. no image whatsoever. it seems like the camera is functioning everything works from what i gather
Since it's a film camera, there are a couple of things to check:
1. You have left the lens cap on.
2. If this is a single lens reflex camera, take the lens off and make sure that the mirror isn't stuck in the "up" position. If it is, GENTLY pull it down until it stays down. At this point, your shutter may be open. Try cocking the shutter again, fire off a test shot, and see if the mirror sticks in the up position. If it does, you probably need to replace the mirror bumper foam - age can make foam deteriorate into a gooey, tar-like substance that can make the mirror stick in the up position.
3. Does the camera have a T (for Time) setting on the shutter speed dial? If so, turn it off the Time setting and set it to a manual shutter speed such as 1/60 - or whatever your 'X' synch speed is.
4. Your batteries died in mid-exposure. Replace the batteries. You may have enough juice in them to show the viewfinder display, but not enough to finish the exposure and close the shutter.
Nov 16, 2017 | Pentax MZ-60 QD 35mm SLR Camera
Can't see through viewfinder
That will happen if the mirror is stuck in the up position and so blocking any light from entering the viewfinder.
Mirror lock-up is very common on 35mm SLR's like yours where the shutter is entirely electronically controlled and in most cases it's cured simply by fitting new batteries.
If this resolves your problem then please rate my answer, if not then add a comment instead to confirm that the batteries have been replaced and I'll try further options.
Apr 26, 2010 | Pentax ZX-50 35mm SLR Camera
The mirror on my pentax pz1 (film) camera is stuck
Mirror lockup often occurs if the batteries are flat.
Try new batteries first and if the problem remains please report back for further options.
Feb 13, 2010 | Pentax PZ-70 QD 35mm SLR Camera
I can't see through my viewfinder
It maybe the case your mirror is stuck in the up position. Take the lens off and see if the mirror is lodged in its up position. If it is stuck get it repaired by a Canon technician
Jul 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Olympus E410 viewfinder problem
As far as I am aware, you can use the viewfinder OR the live view, but not both at the same time.
This is because a mirror has to flip up out of the way to reveal the sensor for the live view to work, and the mirror needs to be in the down position to reflect the image into the viewfinder.
Switch between the two modes and double-check if there is a problem.
Also try removing the lens from the camera and checking the position of the mirror. It could be that it has got stuck in the up osition.
Hope this helps!
Jun 27, 2009 | Olympus EVOLT E-410 Digital Camera
Black viewfinder
Slr mirror is stuck. remove the lens and try to slightly move the mirror up and down ( but not forcing it to move!)and pushing the shutter switch. Try also applying lighter fluid in the mechanism while operating or shooting, fluid will help loosen the stucked mechanism.
Aug 31, 2007 | Pentax ZX-7 35mm SLR Camera
Viewfinder Blank
This suggests the mirror is stuck up in the take position. Remove the Lens and look at what is behind it In the rest mode you should see a mirror. If it is stuck up you would see the sensor window Which do you see. with the lens off - can the camera be switched on? This might just drop the mirror The mirror is surface silvered - do not touch it. If it still up then it is a repair shop/warranty replacement job.
May 07, 2007 | Nikon D50 Digital Camera
Photography Logo
572 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
