Question about Samsung SGH-E900 Cellular Phone
Replacing Housing I have got the housing on my E900 scratched and I dont no how to change it. I only need to know how to change the front housing. Please Help, Thanks, James Coombs, (Coombsie)
  • 2 more comments
  • terrie123 May 10, 2008
    I am having the same problem, need to change housing on my Samsung E900, anyone know how.
  • Anonymous Jan 08, 2009
    i wish to change the housing on my samsung e900 how do i do it
  • Anonymous Jan 10, 2009
    i want to change the entire housing of my SGH-E900 because its all scratched and i don't know how....
  • Anonymous Feb 23, 2009
    I dont know how to fix the front housing of my Samsung Mobile Mod E900please
Provide me the process by which ur r following is it through
blue tooth
cable connetion.
Posted on Feb 07, 2008
Step by step replacing the thermostat
Break free 2 bolts on thermostat housing, loosen hose going into housing and clamp, it will leak some antifreeze. Once the housing is taken off block clean off old gasket material from both surfaces. The block and housing, be careful not to scratch the surfaces. No sharp pointy objects, aluminum is soft. Then take the old thermostat out and put in the new one. Put gasket in place ,align housing and put , bolts in by hand first, so it doesn't cross thread. Just snug bolts and top off system with antifreeze . Start engine ,put on heat and run until thermostat opens. Check for leaks, tighten bolts 1/4 turn should be fine. Add antifreeze in overflow bottle if needed.
Dec 05, 2014 | 2001 Chrysler Voyager
How do you change the housing on an LG VX 9800 phone. The phone is to scratched up
Hi.. if you want to change the housing you need to get the casing first then remove the screw to change the housing
Good luck!!!
Jul 07, 2009 | LG VX9800 Cellular Phone
Toochscreen stop responding on HP iPAQ hw6945
Hi!... Maybe you forgot to install the plastic membrane attached in the front housing?... Check it maybe you forgot to install it...
Jun 19, 2009 | HP iPAQ hw6945 Smartphone
Htc Universal outer cover/panel/body
dont need a guide. there is 4 screws on the back, then unclips.
the front pannel has 4 more screws ull be able to see, when the back is off.
the rest is straight forward my friend. i did it just this christmas..
just take your time.
use a small flat-headed screwdriver to lift the pannels off and on.
Jun 01, 2009 | HTC P3300 Smartphone
Replacing the thermostat on a cadillac deville
drain half of the coolant.follow top hose to the thermmostat housing .loosen hose clamp then loosen the thermostat bolts.remove the thermostat housing and thermostat.remove traces of all the old gasket from housing and the intake where thermostat goes.becareful dont scratch the surfaces while removing all the old gasket.this info is for the 4.9 for the 4.6 engines. you have to remove radiator support cover .remove the air filter housing.loosen hose clamps .remove your thermostat housing bolts then thermostat.remove traces of all old gasket.on thermostat housing and intake. then put in new thermostat in. put on housing .torque bolts 18 to 20 ft lbs.
Apr 13, 2009 | 1995 Cadillac DeVille
Left front turn sinal lamp burnt out;needs replacing
I believe there is a couple of screws under hood at housing, maybe down the side, and a plug inside fender, in front of wheel that you turn & pull out, to undo fastener at rear of housing, then pull housing right out to change it.
Apr 05, 2009 | 2004 Dodge Ram 1500
Changing a ribbon on my samsung e 900 I'm sure you will know how to use this page.There are pictures how to disassembly and assembly E900. If you don't have a soldering iron you can cut off those soldered pieces (even I hate people what do this :) ), but take care about flex cable. Enjoy and take care, mate ;) Level4 tech.
Sep 23, 2007 | Samsung SGH-E900 Cellular Phone
How to replace the lcd screen on a samsung e900
hello steve1969
see this link
be carefull .
Aug 21, 2007 | Samsung SGH-E900 Cellular Phone
Samsung SGH-E900 Cellular Phone Logo
202 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
