Question about Sylvania 6432GG 32" TV
The tv keeps blowing fuses
The tv takes a 4a 125v fuse and i bought a 4 pack at radio shack and soon as i replaced the fuse and plug it in before i got to turn it on the fuse blows...so if anyone can help i need it thanks
  • Sylvania Master
  • 12,061 Answers
Hi your problem is that a component(s) inside your TV has probably short circuited to Earth, this then causes a massive current to flow and this blows the fuse. Due to the types of Component failure from this, this TV should go to a reputable repair shop. Get a firm "Quote" and an explanation of what needs to be done.
Posted on Aug 15, 2007
SOURCE:
I just got a free sharp LCD LC19SB27UT and it has a power problem, I opened it up and notice a fuse was dead, this all happened because a friend was using it in a thunder storm, I went to radio shack and...
on the power board you will see a black flat ac converter with this on it + ~ ~ - on it check this with a meter its more than likely to have gone as its the first thing to go in a storm. the + and - can be the other way round ~ ~ is the mains volts in and + - is the volts out if the ~ ~ has no resistance it has blown and it will keep blowing the fuse check the + - and you should have a resistance from the rest of the power board.
Jun 05, 2017 | Sharp LC19SB27UT LCD TV
I went to Radio Shack to buy my open 6.3 slow-blow
Yes you can try it,Go to this website Mats Electronics they list all kinds of Parts/Supplies
1-800-628-1118
Apr 28, 2010 | Panasonic CT-36SX12 36" TV
Tv problem with a fuse
Your degausing thermistor is bad and needs to be replaced. The part number is D4DDF1R50001
Once that is replaced put a new fuse in put the set back together and you should be good to go. You will need to replace the fuse with the correct size and its part number is
XBA2A00101F
Sep 10, 2009 | Panasonic CT-36SX12 36" TV
Panasonic ct-32sl13g blowing fuse by power supply
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Apr 15, 2009 | Panasonic CT-32SL13 32" TV
Tv shutting of after 1 min then its on for 5 min then
Fuse, board-mounted, 4a mini AGC glass, 125v.
4-pack at Radio shack runs $4. USD.
Jul 29, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Sylvania lcd color tv
if you have replaced the fuse already then you know how to open the back of the set . The problem is more than likely one of the diodes in the rectifer circuit . They will be the four large black components The bad one will have to be desoldered and a new one soldered in its place . It will take a small amount of technicial ability but can be done easily at home.
Mar 25, 2008 | Sylvania LC320SS8 32 in. LCD Television
I can't find a 6.3 125v fuse
If you look on the board that the fuse sits on you will see printed it states 6amp 125 Volt / 3amp 250Volt. This means that you can use either one. I think that is why the fuse states E.6.3 125Volt... I think it means either 6 amp (125 Volt) or 3 amp (250 volt). I noticed on the back of a fuse package that I bought that it stated these were interchangable so I put two and two together.
Jan 11, 2008 | Panasonic CT-36SX12 36" TV
Replace the FU303 fuse
I have just been buying it at radio shack. However in my case it seems once the fuse blew for the 1st time, it happens now every few months -- so must be a symptom of a larger issue.
Dec 18, 2007 | Pioneer SD-643HD5 64" Rear Projection...
6.3a slow-blow 125v fuse
It will work, the amp rating is most important, 125v / 250v does
not matter.......note: if you blow the fuse again, the TV will
need service.................T.
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
6.3 slow-blow fuse
Important parameter is 6.3 amp slow-blow,voltage rating = 125v
or 250v OK, No Worries.............................T,
Sylvania 6432GG 32" TV Logo
421 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
