Question about GE Spacemaker JVM1640SJ Microwave Oven
1800 XL JVM1860BD - won't work
Symptoms; Open door and the light come on (flickers) and buzzing/humming sound occurs, shut door and light stays on with buzz/hum for 1-2 minutes then goes off; Press vent fans/surface light button and the fans/lights come on with buzz/hum. Vent fans work but the grill cover does not flip open. There is sometimes a delay in lights/fan turning off. Press express cook 1:00 or add 30 seconds and desplays shows PAUSED with buzz/hum. Continue start button does not respond; Cancel button does shut it off. I have replaced the latch body and all three door switches but symptoms still the same. Any advice?
  • GE Master
  • 9,156 Answers
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
Posted on Sep 28, 2007
SOURCE:
RE: Samsung microwave SMH7187STG mfg'd 5/08. I heated cup of tea 2 min.Then I closed micro's door & micro emitted a continuous electrical buzzing sound.I opened door & buzzing stopped.
The cook relay on your control board is shorted, and the unit is cooking whenever you close the door.
When the magnetron overheats, its thermostat opens, shutting power down until the unit cools to a safe level, then power is restored.
I regularly repair these with my $54.95 service, which includes insured return shipping.
Details are here, or for full information and instructions, please e-mail me here at pupista@gmail.com and remind me of your full model number and symptoms.
Dec 20, 2016 | Samsung Microwave Ovens
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
GE Spacemaker XL 1800 Microwave. After removing heated food, I closed the door and the microwave sounded like it was powering up again. However, no internal light came on as it does when the unit is...
Be sure to keep this oven unplugged or the door open until it is fixed. If it runs by itself, this is a fire hazard.
First listen carefully for a buzzing sound behind the control panel when the door is shut.
If it's present, chances are you have a failing capacitor on the control panel assembly, which can be repaired for $39.95 in most cases. Details are here.
If that or a louder buzzing is only present when you have the door closed, then the oven is cooking when it's not supposed to, but the cooling fan is not on, and it is overheating and tripping the breaker.
That would be due to a shorted cook relay on the control board. That can also be repaired with our $39.95 service.
The odd characters on the display concern me separately. This could mean you have a noisy or otherwise failing magnetron.
If the display is fine when you're cooking properly with it, then the magnetron is probably okay.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Apr 28, 2011 | Microwave Ovens
GE 1800 xl microwave is making buzzing sound when any key is pushed. Does not work at all only buzzing sounds coming from the top right
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
Jan 15, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker XL 1800; Model JVM1860 CD 001; Manufactured Nov. 2001 When opening the door or pressing any menu option, a constant buzzing sound occurs. The unit does not respond other than the...
We see (and repair) this a lot. The problem is electrolytic capacitor that fails on the control circuit board, which we regularly repair nationwide by mail for $39.95 postpaid with a one-year repair guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Nov 22, 2010 | GE XL1800 1100 Watts Microwave Oven
Works - but the sound has changed
Possibly, the "fault" was the buzzing in the first place! Buzzing is usually a cabinet vibration caused by magnetic fields from the "gubbins". If the buzzing should occur again, try pushing/ pulling/ poking the cabinet while the oven is running, you may find a position that causes the buzz to stop.
Another possibility is you previously had something else placed in close proximity to the oven.
If a rattling cabinet is the problem, either try to reposition something, or just ignore it!
Apr 29, 2008 | Maytag MMV4205 Microwave Oven
G.E. Spacemaker XL1800- Loud constant buzzing noise. Help
My microwave was totally dead. Things I discovered: 1) There is an easily replacable fuse accessed by taking off the top front vent cover (two screws on top, gently massage off) and then the inside plastic grill. UNPLUG before doing this! 2) Pop off two wires on either end of fuse holder for safety. Then pop out fuse and replace. For more extensive help, there is an evelope with a wiring diagram inside the case on the inside wall! Very helpful when diagnosing the surface lamp problem (I forgot to plug the ballast back in when I closed up the bottom).
Mar 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My Microwave flickers and buzzes
This problem normaly happens when the door is not closed properly for a long time and flashing and buzzing starts to give user a indication for same. Allthough it is not risky as microwave oven has safty door switches wich does not allow oven to operate while door is open. Take care and close the door properly before you leave kitchen..
Aug 02, 2007 | Kenmore 66469 / 66462 / 66464 Microwave...
GE Spacemaker JVM1640SJ Microwave Oven Logo
823 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
