Question about Grilling
Propane grill uneven heat
I have a new 4 burner propane grill from sams club members mark.
When I light all 4 burners, the two center burners get hot, 500 + degrees, but the outer burners only get to 350. I have done the reset the regulator thing multiple times two different ways after researching this for many days on line with no change. If I light just the two left burners the far left will get to 500 degrees and when I light just the two right burners the far right will get to 500 degrees. I therefore know that all four burners can get to 500 degrees, so its not the burners.
If I light either the two left or the two right burners and they get to 500 degrees, as soon as I light another burner the temp drops.
Hope you can help
Thanks
Mitch
  • 5 Answers
Make sure the burner are clean. Or Just purchase a Weber. There customer service is #1
Posted on Mar 27, 2017
  • Grilling Master
  • 3,239 Answers
Could it be the draw off the tank is okay for two burners and not 4 hence the temp drop
  • 32 Answers
SOURCE: jenn air 32 in. 4 burner gas grill
HAVE YOU TRIED THE ORIIGONAL TANK? SOME COMPANIES HAVE SPECIFIC TOLERANCES FOR FITTINGS THAT MAY NOT WORK W/ OTHER ITEMS.
Posted on Apr 08, 2008
  • 24 Answers
SOURCE: My grill does not heat beyond 300 degrees.
Check the excess flow safety device, which is part if the barbeque to cylinder connection, may have activated. To reset the excess flow safety device turn all burner control knobs and the cylinder valve off.
Disconnect the regulator from the cylinder. Turn burner control knobs to high. Wait at least 1 minute . Turn burner control knobs OFF. Reconnect the regulator to the cylinder. turn cylinder valve slowly. I HAD THIS PROBLEM JUST LAST NIGHT AND FIXED IT RIGHT THEN.
Posted on May 23, 2009
  • 24 Answers
Posted on May 24, 2009
radar001
  • 1051 Answers
SOURCE: Genesis Silver B Grill: grill won't heat past 350 or so. put a new regulat...
An odd thing with many propane gas grills is how the regulator functions. If the tank is opened too fast the regulator over-adjusts and delivers no gas. Try this: Turn tank off and open all burner controls. This should clear the line of any gas. Close burner controls and open tank very slow. Now lite and temp should go up.
Posted on May 19, 2010
  • 333 Answers
SOURCE: I am getting very low
could be the regulator
Posted on Aug 15, 2010
Can a Turbo STS 3 burner grill (720-0057-3b) be convert from natural gas to propane? Barbeque Galore has gone bankrupt and does not offer any assistance at their 1 800 number and I can't find any...
The original BBQ's Galore went bankrupt, but was bought by new owners, who still operate it as BBQ's Galore. However, they did buy any of the older company's parts supply. However, all you need are the burner orifices for each burner (including the rear burner) and a Hose/Regulator Assembly to connect the grill to the grill tank. Follow the conversion instructions in the Owner's Manual (see link below) and you should be able to do it.
http://www.grill-repair.com/images/grill/turbosts.pdf
I suspect if you call BBQ's Customer Support 800-752-3085. They can provide the orifices, as they are universal in fit. The Hose/Regulator Assembly can be purchased from any hardware store or home improvement center that sells grills and accessories, for about $30.00.
Once converted, you will see marked improvement in the heating capacity of Propane Gas, as opposed to Natural Gas. The grill will preheat faster and maintain higher temperatures longer.
I hope this helped you, Bradley and thanks for choosing FixYa. Happy Grilling!!
Aug 10, 2011 | Barbeques Galore Turbo STS 4-Burner with...
I have a brand new , full tank of propane. I cannot get the propane from the tank to the burners. I am not sure if Ihave a bad hose and regulator or a bad valve that will nto allow the propane to flow...
Julian, let's get this corrected for your 4th of July Cookout.
1. Turn the tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the valve is fully open, light the burner farthest from the tank first & turn it to HIGH.
Did the burner light and the fa,e height look correct? If so, light the remaining burner exactly
the same way. Now, do all the flame heights look correct? If so, you solved the problem.
Always remember to turn the tank valve ON Very, Very Slowly.
If the above didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly, as the regulator is locked up. You can pick one up from any home center or hardware store that sell grills and accessories for about $30.00. Take your old one with you for comparison purposes.
I hope this helped you troubleshoot and solve the problem, Please let me know and Happy Grilling!!
Jul 04, 2011 | Weber Genesis E-310 Gas Grill
My propane tank is full, but none of my 3 burners come on, 1 does very slightly but then goes out, help! thanks
Turn the propane tank valve to OFF. Disconnect the hose from the tank and wait 5 minutes. Then, reconnect the hose to the tank and turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the tank valve is fully open, light the burner farthest from the tank first and turn the burner knob to high. Does the flame height look as it should? I f it does, light the remaining burners the same way, one at a time. Do all the burners burn as they should? If so, you solved the problem. If not, you need to replace the grill hose/regulator assembly. You can get one from any home center or hardware store that sells gas grills and accessories. Just take your old one with you for comparison purposes.
Hope this helps and Happy Grilling!
Apr 10, 2011 | Brinkmann Charmglow Stainless Steel LP...
I just purchased a brand new tank of propane and i still have the same problem that the propane burns out of all 4 burners but at a really low flame even on high. I can not get the grill to heat up...
Turn the tank off. Disconnect the grill hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the LP tank valve on VERY, VERY SLOWLY until it's fully open. Now, light each burner one at a time and turn it up to the highest setting. If that didn't solve the problem, repeat the previously listed steps.
If after the second attempt the burners still only maintain a low flame, you will need to replace the grill hose/regulator.
Hope this solved your problem and Happy Grilling!
Feb 27, 2011 | Brinkmann Charmglow Stainless Steel LP...
We have a spirit grill with 3 burners. I can light the grill, but burners 1 & 2 don't have a nice line of blue flame like burner 3. Burner 2 is especially bad with orange flames on the right and left...
Are you sure there's adequate gas in the tan? If so do the following:
Disconnect the LP tank from the grill hose. Wait 5 minutes and reconnect to the tank. Open the tank valve VERY,VERY SLOWLY, until it is full open. Light your burners individually and turn to highest flame setting, before lighting the next burner and so on.
If that solved your problem GREAT. Remember to turn the tank on that way in the future.
If it didn't you'll need to remove the burners and clean each one.
Hope this helped to get you back up and grilling again.
Feb 18, 2011 | Weber Spirit? E-310 Propane Grill
I'm aving a low flame issue. I replaced the burneres and heat shields a couple of months ago, worked great for a while, but now the flame on all 4 burners is low. When the heat is turned down to half...
If you're turning off your propane tank after each use (which is fine), you will need to turn it back on very, very slowly. The new OPD valves that are now required on all portable propane tanks, will lock up the regulator if it's turned on to fast. Also, check all the pilot orifices for clogs. And finally, be sure you have enough gas in the tank.
Jan 19, 2011 | Barbeques Galore Turbo STS 4-Burner with...
Middle burner looks ok but has huge yellow flame
Sounds to me like the new burner that was put on, has the wrong gas orifice in it. Possibly a nat gas orifice instead of a propane orifice. If it's a propane grill, take it to your local propane co and have them look at it. Also, sometimes just a spiderweb or dirt dobber nest in the burner's venturi tube can cause that kind of problem. Blow it out with an air compressor and see if that's the problem.
May 14, 2010 | Weber Genesis Silver B Grill
I can not get any gas pressure in main burners or side burner, i have a new propane tank, just a trickle of gas not even enough to keep side burner going when only using side burner, will only produce a...
Look for spider webs in the venturi tubes, check the orfices or it could be faulty controls. Verify the tank working properly by trying on another grill.
Eric
Jan 24, 2010 | Brinkmann Charmglow 810-7400-S Propane...
Grilling Logo
741 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
