Question about E.Digital Odyssey 300 128 MB MP3 Player
Need software to download recorder audio
Can you please tell me where I can download the software for this device? I've recorded some audio and want to download from the device, but my PC does not see the device.
I had the same problem. put a sd memory card into the slot then thee pc will reconise it
Posted on Jan 30, 2009
Gigaware no sound
If you have audio cables from your source connected to the capture card, then your Recording device needs to be the Line In of the capture card.
If you connect the source to the Line In on the computer, then you use that as the default recording device. Until I set this, the default audio recording device was my microphone (not connected at the time). In Windows, you need the Manage Audio Devices Recording tab. (In Windows 7 and 8, it's under Control Panel > Hardware and Sound > Sound > Manage Audio Devices.)
If you are recording something playing on your computer, then the stereo mix option may work.
You should be able to use any video&audio software if the drivers are compatible. Thus the software you used for the video recording should work. (Stereo mix may be an exception - not all sound cards actually work when you try to record that content.)
I hope this helps.
Dec 03, 2013 | Televison & Video
I can't find the drivers for my Olympus Digital voice recorder VN-2000PC. What can I do? I can't tranfers my audio files to my PC.
Do you need the software/drivers for the VN-2000PC or the VN-2100PC? The software for the VN-2100PC is available here: http://www.olympusamerica.com/cpg_section/cpg_support_downloads.asp?id=1270 . Select your OS and you'll find the software.
The VN-2000PC doesn't connect to the computer via a USB port. To transfer your files to a computer, connect the earphone jack to the line In (blue) jack of the computer with a 3.5mm to 3.5 mm audio patch cable. Use a program like Audacity to record the audio track during playback. Make sure to set the Audio input to Line In. (In Windows 7, click Start > Control Panel > Hardware and Sound. Under Sound, click Manage Audio Devices. Then select the Recording tab and set the input device.) Then set the recording device in the software as well. Click the Record button in the software and then start the play back on your VN-2000PC. You should see a flat line for a bit then see a wave form start. If the line stays flat, you haven't set the Line In device properly.
I hope this helps.
Sep 01, 2012 | Olympus VN-2100PC Digital Voice Recorder
How transfer music to nook
First in the OS make sure that recording device is USB (Start > Setting > Control Panel > Sounds and Audio > Audio). Adjust the audio recording volume, as well (Start > Programs > Accessories > Entertainment > Volume Control > Options> Properties. Click on Adjust Volume For Recording, for some versions of Windows). Unfortunately you can't directly listen to the recording on USB in this software. You would need a regular turntable with amplifier and then RCA L/R audio to 3.5 mm audio adapters. Connect this to the Line In of the computer (blue port) on the sound card. Then set the recording device to Line In and unmute Line-In in a similar way as above.
Now try recording in Cakewalk Pyro. (I recommend making a short recording and then playing it back to check the settings.) Try the Windows Sound Recorder (similar to finding the audio recording volume) to record if Pyro doesn't work. You may have a problem with the USB turntable or your USB port. You should see a waveform if the software is recording anything. Adjust the audio so that the entire waveform is consistently less than 100% of the maximum. A flat line in the center of the audio trace is a sign that there is no incoming audio signal. I usually start the software recording and then start the turntable at the correct track. Thus a flat line for a few (~10 seconds on my system) is normal.
After recording, you need to export the file or files as MP3s. (I subdivide a longer recording into tracks but that can be a pain. Identifying the "break points" is not always obvious.) Then File > Export (iirc). Select the MP3 option and the quality. I put all my music into the myusername/music/recordings subfolder (I created the folder) to make them easier to find again.
Connect the USB cable from the Nook to the computer. Access the Nook from the File Explorer. (Double-click on the Computer (My Computer) icon with Windows, it's the Devices icon on a Mac.) Then double-click on the Nook's icon (there may be more than one).
Open a second explorer window to the directory where you saved the MP3s. Then just drag and drop the files/folders to the Nook. If you put the files onto the internal memory of the Nook, make sure to put them in the My Music or My Audiobooks folders. (You can do transfer the files to the memory card without plugging in the USB cable, if you have a card reader. Just be careful not to lock the read/write switch on the card and do not reformat it.)
I've used several programs and found Audacity (free) to be just as good and straight-forward to use. However, the programs all work the same way. If the USB device isn't working (or the default recording device), you get nothing.
I hope this helps.
(I will note that most of my recordings were done from cassettes using Line-in from the headphone jack. Thus I only had to diagnose problems with the patch cable and the default recording device once I checked that my headphones worked for the tape. I saved my recordings as WAV and then burned them to CD as Disc At Once for a player that didn't read MP3s.)
Jun 22, 2012 | Cakewalk pyro 5 Full Version for PC
Thing is that im recording a song. After recording when i try to play it, it doesnt give any sound. Im positive that it records fine. Any solutions?
This is totally dependent on the software you are using to record.
Not knowing what you are using makes any response a wild guess.
IN GENERAL you must configure both the input and output device within the recording software you are using.
I use Sonar and one has to select the audio input and output device and tell the program which device is used for timing.
Aug 07, 2010 | Lexicon Alpha Personal Recording Studio
Ive been able to record and now i cant record bcuz the screen says "no inputs..." but i can hear music thru the inputs and the lexicon alpha is selected as the input and output sourc. whats wrong????
It sounds like you have NOT connected via the recording software.
It is like the normal Windows software audio has hijacked the audio system even though it is external.
Go into your recording software and look for an option to select the Lexicon device. You did not tell us what recording software you are using.
This is not an uncommon problem with these external audio recording devices.
Apr 14, 2010 | Lexicon Alpha Personal Recording Studio
VISTA DOESN,T RECOGNIZE SOFTWARE
copy and paste the link below...it tell you all about your recorder...
http://www.microsoft.com/windows/compatibility/Details.aspx?type=Hardware&p=DVC%20100%20(Dazzle%20DVD%20Recorder)&v=Pinnacle%20Systems&uid=DVC%20100&pf=0&pi=0&s=DAZZLE%20INSTANT%20DVD%20RECORDER&os=32-bit
Hope this does the trick for you, I'm sure it will.
good luck, please leave rating. thank you kindly
Apr 26, 2009 | Computers & Internet
Lost Original CD/drivers for Panasonic RR-US430
Software available here:
http://thepiratebay.org/torrent/4404636/Panasonic_Voice_Editing_2.0_Standard_for_RR-US430
Use BitTorrent to download.
Dec 15, 2008 | Panasonic RR-US050 Digital Voice Recorder
Audio Recording
There are many streaming audio recorder. But I prefer Wondershare Streaming Audio Recorder,It can download streaming video offline,you can download aol radio,myspace music and so on.
http://www.download-streaming-video.com/streaming-audio-recoder/#137
You can have a try.
Mar 28, 2008 | Dell Dimension 3000 PC Desktop
I need a software to download the recorded cassete to my system
There is no software that comes with the camera. It is up to whatever application you are using to edit the video to import it.
Oct 23, 2007 | Canon ZR500 Mini DV Digital Camcorder
E.Digital Odyssey 300 128 MB MP3 Player Logo
Top E.Digital Audio Players & Recorders Experts
Robert Graf
Mai Lor
Isabella Lee
Isabella Lee
Are you an E.Digital Audio Player and Recorder Expert? Answer questions, earn points and help others
