Hi - I have a GE simon #3 system and I have a sensor that went bad. I have a new sensor I want to replace it with, but no matter what I do I can't delete the old sensor. I go through the delete menu, it deletes, but isn't really gone. Help?? I am perfectly willing to do a complete reset of the alarm and delete everything, but I can't find how to do that either.
thanks!!
In order to do this, you must have the "installer code". This is not to be confused with your master code which you use to disarm your system. Once you have this code, enter it when prompted, press delete, press sensors, when proper sensor is announced press done to accept, system announces that sensor "x" has been deleted. There is a default "installer code" (1234 or 4321) but many suppliers such as ADT change it to prevent owner tampering.
have a issue that indicted a low battery replaced the battery have 7.1vdc at the main board when...
(More)
have a issue that indicted a low battery replaced the battery have 7.1vdc at the main board when checking system status still saying low battery,
My Optima XM6 fuse blew,I powered the system down,replaced the fuse and battery when I connect it...
(More)
My Optima XM6 fuse blew,I powered the system down,replaced the fuse and battery when I connect it back up the alarm sounds and the code number will not stop it.How do I remedy this?Thanks.
I set the new Simon 3 system with a 4 digit master code...but then when I try to add an access code...
(More)
I set the new Simon 3 system with a 4 digit master code...but then when I try to add an access code for the mother, it says invalid or cannot be used. Does it matter if I duplicate digits??? example code: 2311
we have had a gemini security system but have not installed it. Then, the baby in the house pressed...
(More)
we have had a gemini security system but have not installed it. Then, the baby in the house pressed on, but no one had a code. it has been going on repedely.
