Question about Philips HTS3450 System
Speakers All Of a sudden the speakers started making a clicking sound
  • edub Dec 01, 2007
    unplugged everyhting and set it all up again and still nothign
I have a similar problem. The set is under warranty and the Philips technician came to check it. he said that if the system is on all the time, the memory gets used and when there is a sudden loud sound in the movie, the balance memory is inadequate to handle the load. he suggested that I keep the set's power switched off and switch on only when I use it. This seems to have made things better.
Posted on Sep 04, 2007
Gigaware speakers suddenly produce no sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope this helps
Nov 27, 2011 | Audio Players & Recorders
My Dell twin speakers suddenly not working today Monday 5.9.11. Were working OK about 3 to 4 days ago. Have not disconnected anything and all plugs seem to be in order. First time this has happened in...
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Sep 05, 2011 | Dell A215 Computer Speakers
I have checked and the speakers are working however I suddenly lost all sound
also
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 05, 2011 | Dell Computers & Internet
Suddenly no sound, lights on, think jacks in right but not sure,speaker jack into orange hole and line in jack into blue hole
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 22, 2011 | Creative Labs Audio Players & Recorders
They are suddenly not working!
also
hope this helps
Apr 27, 2011 | Logitech Z323 2 Speakers
No sound.suddenly stopped working
also
hope this helps
Apr 19, 2011 | Audio Players & Recorders
My speakers were working for 3 years, all was ok, but suddenly I deleted something, and they stopped to work!
also
hope this helps
Apr 10, 2011 | Creative Labs I-Trigue 3220 Computer...
My speakers just suddenly stopped working its like theres no more power going through it, I've tried unplugging it and it still won't work. What should I do?
also
hope this helps
Mar 23, 2011 | Creative Technology Creative Inspire T3130...
Speakers have been working fine for a couple of years, suddenly cut out and im not sure if they are broken or not, have all the updated drivers, have tested other speakers so its not my sound card.
also
hope this helps
Mar 21, 2011 | Labtec Spin 55 Computer Speakers
All of a sudden, the sound level became very low
the drivers might have been corrupted by something foreign or you might have got a virus run your antivrus program
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 12, 2011 | Logitech X-240 2.1 Speaker System with MP3...
Philips HTS3450 System Logo
63 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
