My Tablet screen for my nextbook is black still I've tried restarting it and everything but it doesn't do anything but show a black screen. And I don't know what to do with it?? What should i do??
If you are still have a light indicator in the battery charge, you are in luck. Recharge completely your tablet before you trying to restart it. Once is fully charge, push the on and the volume button at the same time, but not for more than 5-6 seconds at the time, and not more often than every 20-30 seconds apart. Hold the volume button by the (-) side not the (+) side when you do that. It should restart the Wizard to reboot and get your tablet back on line...
SOURCE: I'm unable to watch any
Hi, just make sure that you are logged in as an administrator so that you will gain full access to your computer. Hope this helps..
SOURCE: Cannot send an email message on gmail from my Galaxy SII tablet
Try "Firefox" Mobile, sounds like browser/sync issues.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/keith_f374b1cfd1696a17
SOURCE: I can't get my NextBook premium 8 tablet to start OR reset.
Check the battery otherwise it is the hardware problem in your tablet pc
SOURCE: tablet crashed won't do anything
plug it in for 5min.then hold the power button for about a min. I hope it works it did for mine.
I don't know if this is available on that model. Give it a try. Press and hold the power button until you get the menu with the option to power it off. Press and hold your finger on the option to power it off for a few seconds. Hopefully you get an option to reboot the tablet into safe mode. This mode will disable all third party apps on the tablet. See if it freezes up. If it doesn't one of the apps is causing it to hang. This will at least tell you if the tablet itself is bad or if it is a problem with an app.
