Question about RCA HD52W56 52" Rear Projection HDTV
Popping sound with interferring horizonal lines until unit warms up.
The unit when first turn on will make a series of popping sounds with horizonal lines interferring with the picture, this will last for about 15 minutes then will clear up.
  • 112 Answers
Do they clear up if you were to walk up to the tv and hit it?
Posted on Dec 20, 2007
SOURCE:
What causes the TV to go on and off when first turned on, until it warms up for 5 to 10 minutes
Try turning the volume all the way down then power the TV an see how
long it takes to bring a screen up if you still hear a popping sound then you have a bad part with a bad connection most likey a lamp and wiring.
Call to have it serviced a must if so.
Jun 08, 2012 | Mitsubishi LT-3280 32 in. LCD HDTV
Microwave popping sounds and flashing lights
The magnetron may be arcing, get warm soapy water and remove all food particals from inside of microwave oven until spotless, and check the hood for bare metal.
Mar 18, 2012 | Hamilton Beach Microwave Ovens
The refrigerator makes a popping sound
sounds like it's your self-defrost working normally as for things freezing,check temps in front and back of refrig and you may be able to raise temp to alleviate condition w/o food in frt end being too warm
Aug 18, 2009 | Refrigerators
M602 Speaker Problem,.. Popping Sound
This worked for me on my M604: Try inserting/removing a headphone plug into the jack several times to see if that clears the problem.
The "popping" sound is very similar to the sound that the unit makes when inserting headphones into the 'headphone' jack on the back of the unit.
The jack has a contact switch that triggers a relay inside the unit. If that contact switch is 'on the verge' of making contact, slight temperature changes may cause deform closer to it's contact target. The subsequent capacitance build-up and discharge across the gap could explain the cycle of popping noises after the unit warms up.
Jun 25, 2009 | Altec Lansing M604 Computer Speakers
Popping (electric) sound from back. Caused breaker to pop. Opened unit to get a better look, nothing broken or blackened. Reset breaker. and turned machine "on". No more popping sound. Washer only fills...
Have a look at the capacitor, this is part of the starting circuit for the electric motor.
It is a cylindrical shape and usually splits or bulges.
Post again if you need further assistance.
Jun 19, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Tv popping sound when turned on
It sounds like you are hearing arcing from the FBT. The FBT should be replaced before it causes something else to fail.
Jan 08, 2009 | RCA Universal Remote Control
Weird Rapid Metallic Popping Sound
I think i have the same problem, but i can get audio still. did the poping plinking sound come from the inside back panel of your TV? it sounded almost like a arc wielding noise?
Sep 29, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
RCA HD52W56 52" Rear Projection HDTV Logo
55 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
