Question about Cuisinart SPB-7 SmartPower Work Top Blender
Lights blink, but Cuisinart Smartpower 7-speed wont turn.
I have a Cuisinart Smartpower electronic blender, model #SPB-7CH(TX5). When I push the on button, the light blinks. When I push a speed button, it also blinks, but the blender does not turn on. Any suggestions?
  • austinhardy Sep 28, 2007
    After spending way too much time on hold, I finally found out that, since the warranty had run out, my options were; A: Pay $50 plus shipping both way for Cuisinart to "look" at the blender and see if they could fix it, then pay repair costs; B: Throw the stupid thing away and buy a new one (which I did). Good luck to you!
  • Anonymous Mar 04, 2008
    Speed lights are on, but blender (Cuisinart Smart Power SPB-7) won't turn.
  • 3 Answers
The thermal fuse is blown. You can buy a replacement from RadioShack for $1.69 You have to remove the old one and solder in the new one. If youre "handy" its very easy. Take it to a repair shop, you pay about the same as a new one. Its too bad that most electronics made today are cheaper to throw away and buy a new one rather than fix them when they break.
Posted on Aug 20, 2008
    New Friend:
Where is the thermal fuse located on this model SPB-7ch (tx5) please give good details thank you for your time
Posted on Jun 07, 2014
I have the same problem. The panel lights work but the motor does not turn.
The machine is less than 6 months old. Can this be fixed under warranty?
Bob B
Posted on Sep 14, 2012
  • 3 Answers
No need to buy anything. The SPB-7 has a thermal fuse to protect the motor in case you overwork it. Per the user's manual, unplug, wait 15 minutes and try again. It worked for me!
Posted on Dec 07, 2013
  • Jeremy Amos
    Jeremy Amos Jun 25, 2017
    How do you get the motor off the base so you can find the thermal fuse? Where is the thermal fuse?
Why does my blender leak?
hi,
sounds like the bearing assembly went, right where the motor connects to the blade, you can get a replacement base from them, have to find the model number and go to their website. doubt you burnt it up. cuisinarts supposedly are commercial quality.
jm
Jul 20, 2017 | Cuisinart SPB-7CH SmartPower 40-Ounce...
I have the cuisinart SPB-7 Smart Power and it leaks. I put my milk in and it run on the counter top. What do I need to replace? Is it the washer?
The bottom part that screws on the jug with the blades, either the o-ring is bad,or the screw on piece is cracked and needs to be replaced.
Mar 17, 2011 | Cuisinart SPB-7 SmartPower Work Top...
Hi, my blender blades won't turn on i have cuisinart blender 7 speed plz help
when the blender cup is not on, does the spindle turn (medal stud looking thing)
and does it do it on all speeds?
Aug 12, 2010 | Cuisinart SPB-7 SmartPower Work Top...
The lights on my cuisinart blender come on but the motor just stopped working
Using your blade holder, turn the motor from the blade end. 1 or two turns. Tak the blade holder out, Plug in an test Sometimes the brushes in the mototor lose a good contact. SGood Luck -Ned-
Sep 19, 2009 | Cuisinart SPB-6 Smartpower 6 Speed Blender
Cuisinart model # SPB-6 (tx) leaking when unit is together, seal is in place, still leaking. Unit is not damaged, please advise.
Check if leaking at the bearing for the blade.
If the bearing has worn, dis-assemble and coat shaft with food-safe grease and re-assemble. Also coat the seals with the grease.
Sep 09, 2009 | Cuisinart SPB-6 Smartpower 6 Speed Blender
My cuisinart spb-7 blender won't spin
How do I replace the blender blade driver clutch? I have the part but do not know how to get it in.
Jun 13, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Leaking cuisinart smart power 7-speed electronic blender
There is probably a hairline fracture or tiny crack in the blade assembly itself - replace the blade assembly - it will automatically come with a gasket, so you will have an extra.
Apr 23, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Cusinert blender
I had the same problem and I manaed to fix my Cuisinart SmartPower Duet blender. There are two thermal fuses, one tape attached to each stator winding. Both of mine were blown.
In addition, when the fuses blew, it must have spiked the triac. I had to replace mine. It's the black 3-legged transistor looking device with a small metal heatsink attached to it. This gizmo directly throttles the power to the motor under control of the microprocessor. There are some guides on the internet on how to test it.
Also, the clutch was very hard to remove and needs to be removed to more easily replace the thermal fuses. I clamped down the end of the motor shaft to a bench vise real hard and then I used a 7/8-inch open-end wrench to wedge into the clutch prongs which made it much easier to apply torque. Remember that its screw threads are reversed from normal screws so that it does not unscrew during operation. You have to turn it counter-clockwise to unthread it.
Hope that helps!
-Vince
Sep 13, 2008 | Cuisinart SPB-7 SmartPower Work Top...
Cusinert blender
you most likely have blown the thermal fuse. I just fixed my blender which had the same problem but only after I bought a another base:< If you are a handy person, it is a very simple fix. buy a 10 amp thermal fuse from "RadioShack" for $1.69. Sadly, it is cheaper to buy a new blender than have it fixed at a repair shop.
Mar 19, 2008 | Cuisinart SPB-7 SmartPower Work Top...
Cuisinart sealing gasket
The gasket goes between the cutting assembly and the glass. So you slip it on over the top of the blades and then put the glass jar over top of that. Screw the bottom cap on to tighten everything together.
Aug 15, 2007 | Cuisinart SPB-7 SmartPower Work Top...
Cuisinart SPB-7 SmartPower Work Top Blender Logo
6,507 people viewed this question
Top Cuisinart Blenders Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
eyecam
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
